Spark Plug Cleaner
Lar
12-28-2000 20:17:54
Looking for a recommendation on a source for a spark plug cleaner that uses abrasives.
Thanks in advance.
Lar
Nathan(GA)
12-31-2000 20:11:40
 Re: Spark Plug Cleaner in reply to Lar, 12-28-2000 20:17:54
I've seen them in a Harbor Freight catalog.
My Uncle has one from many years ago, he bought from a local tool supplier.
Larry Garbarek
12-29-2000 05:53:04
I've heard that some spark plug cleaners work well enough but the abrasive used might find its way into you engine, causing big problems. Don't know if this is a real or imagined problem, but, I wonder if it is worthwhile taking the chance.
T_Bone
12-28-2000 22:11:51
Hi Lar, save your money and buy new sparkplugs as most of them don't work.
T_Bone
Greg D.
12-29-2000 17:32:07
 Re: Re: Spark Plug Cleaner in reply to T_Bone, 12-28-2000 22:11:51
Yes the cleaners DO work, but as Larry said the most important thing is to be sure to get ALL the abrasive material out of the plug before using it again. I have used Brake-Kleen and blown them out with air to clean them. The drawback to cleaning them? It will make the porcelain porous to the point that it will foul easier. So yes they do work, but at best are a short term fix when a new plug is not available
