Tool Talk Discussion Forum
Mig Welder
JeremyR
03-11-2005 16:55:52
I'm new to welding and have been pricing new mig welder's and narrowwed to 3:
1. Millermatic 135
2. Hobart Handler 180
3. Lincoln Sp175 I'll be using it for some projects and repair work around the house. 220 volt is not a problem.
opinions are welcome.
Jeremy
TRUCKER
03-13-2005 08:39:41
 Re: Mig Welder in reply to JeremyR, 03-11-2005 16:55:52
HTP has an 800 number that is 1 800 USA WELD.The website is HTP America welding products.
trucker
03-13-2005 08:35:01
I have a HTP mig,the smallest 220 they make and it works good on thin metal and you can weld 1/4 inch steel easy in one pass.They also offer a video that shows how to weld with a mig.I have a lot of experience welding,but the video showed me a lot that I didnt know.
jhill
03-12-2005 05:48:44
I have the same problem I lent my Lincoln 130 to friend and now I am having trouble getting it back. I really like mine for light work.
MarkB_MI
03-12-2005 05:25:24
I have a Lincoln SP170T, which is the predecessor of the SP175. I've been happy with it. My brother-in-law, who does body work on the side, has used it more than me. He liked it so much he went and bought an SP175 for himself.
TimV
03-11-2005 19:19:33
Jeremy: The big thing is what do you plan on doing with this welder? If you"re planning on doing any sort of heavy fabrication or repair, by all means go with a 220 Mig. I love my Hobart Handler 135 (110V) but it"s an invitation to frustration to try to weld any thicker than 1/8" with it. A 220 machine is much more versatile--turn it down to weld thinner stuff and up to weld thicker stock. I assume you are going with a gas rig regardless of your choice of machine. If not, you probably should consider it--much cleaner welds and less spatter.
ljl
03-11-2005 18:57:02
those that you have mention fine for lith duty maybe 30% and lite sheet metal if you are going to use for serious work get at least a 250 amp and higher duty percentage ihave made that mistake just cost in the end when you go back to town and buy the bigger unit my 2 cents ljl
Opa A
03-11-2005 18:56:38
I have a Miller XP135, 110 volt. Use .030 solid wire and love it. Will weld 3/16" mild steel one pass no problem. Can't beat the portability.
Check out Miller's web site, forum there with lots of great info. My 2 bits
Garett
Coloken
03-11-2005 18:00:52
I have a 110 volt 135 amp mig. While some seem to think they are OK for fenders and such...don't buy one. Get a 220 volt one if you have the outlet. If you don't have a 220 volt outlet, get one.
