Tool Talk Discussion Forum
Poulan chainsaw
DaveM in GA.
03-10-2005 08:16:07
I have an old Poulan SD25 chainsaw. The starter rope will not pull, but pulls easily if I remove spark plug. It"s as if I am pulling against a vacuum. I"ve cleaned exhaust, carb, fuel filter,etc. but no change. Does this sound like reed valves stuck and if so, can they be cleaned? Any easy way to do it?
Bob - MI
03-10-2005 10:28:21
 Re: Poulan chainsaw in reply to DaveM in GA., 03-10-2005 08:16:07
Reeds are in between the carb and the crankcase. I have never heard of a set doing this but from what you describe it may be it. You could try some wd-40 or some aerosol solvent through the carb throat to loosen things up. If that fails pull the carb off and you should be able to identify the reed cage. I wonder if this has been serviced by someone else and they possibly installed the reeds & cage backwards? I would also check to make sure that someone didn"t put too long of a plug in it. Could be hitting the piston.
DaveM. in GA.
03-11-2005 11:52:56
 Re: Poulan chainsaw in reply to Bob - MI, 03-10-2005 10:28:21
Fixed it. Reed valves were gummed up. Removed carb and poured lacquer thinner in crankcase, followed by WD-40 and compressed air. More WD, then cranked it, smoked for awhile, but running great! Thanx!
