Tool Talk Discussion Forum
concrete recipe
Rudy_Wonders
03-08-2005 16:31:44
In the concrete Recipe it says 1 part cement, 2 1/2 sand, 2 1/2 gravel, and 1/2 water. Ok my question is: If 1 part = 94lbs. of portland cement. And the slab needs to be 4 inches thick. How much of the area would be covered with concrete in cubic feet?
dr.sportster
03-10-2005 07:08:43
 Re: concrete recipe in reply to Rudy_Wonders, 03-08-2005 16:31:44
You calla fora concrete.Bigga truck she a come.
36BinMN
03-09-2005 20:58:12
third party image
This is one of my jobs. Take it for what it's worth get the ready mix. I pour the stuff almost every day. And yes this IS concrete.
36BinMN
03-09-2005 20:45:57
third party image
Hey Rudy, I don't profess to know how much of what goes into a particular concrete mix. BUT I do know that mixing it your self is not a good option if you are planning to cover more than 100 sq ft. the cost of ready mix is between 65 & 80 a cubic yard. Take your simple bag of sackcrete at 3-4 dollars a bag it will cost 81 to 108 at 1 cubic foot per bag to get the same amount of concrete. You may have a small delivery charge for a 1 yard load though, but the hassle of mixing it your self isn't worth it plus the quality is of the concrete is not near as good this is a pic of a scale you can copy or you can get one from your local concrete place, take your length x width to find total sq. ft. and find your depth on the scale to see how many sq ft. you will get out of a yard of concrete find your cubic YARDS needed and add a 1/4 or 1/2 for errs depending on the size of your pad!
This muds for you
03-09-2005 14:50:30
I would like to give you something to consider. If you have much more than 81 sq ft @ 4" deep why don't you call your local redi mix concrete company? In my area of N Mich you can buy concrete for 70-75.00 per yard if you figure buying 5-6 bags of cement at 8.50 a bag plus the correct aggregate plus your time to mix in small batches and pour and screed and finish. You will receive a superior product from a reputable supplier than trying to mix your own. Good luck on your project
txblu
03-09-2005 07:10:17
81 sq ft of surface area for 2x4 form.
Greywolf
03-09-2005 07:39:26
 Re: concrete recipe in reply to txblu, 03-09-2005 07:10:17
Actually a 2 X 4 form is only 3.5 inches and then it becomes 88 sq ft to equal a cubic yard.
txblu
03-10-2005 05:42:27
 Re: concrete recipe in reply to Greywolf, 03-09-2005 07:39:26
Yeah but my cushon sand isn't perfectly level with the bottom of the 2x4 so I need the extra half inch. Grin.
Mark
Galen
03-08-2005 19:45:54
Uh.....you're 94# bag of Portland Cement will cover a lot more than 1 cubic foot. Depending on the aggregate (rock), you should use between 5 and 7 bags per cubic YARD. Quikrete mixes will cover about 1-2 cubic FEET per bag. Figure 6 bags of Portland per yard and if you have extra, return it. What is the area you are working with? Formula: (Length x Width x Thickness) divided by 27 = cubic yards. Add a little for irregularities.
1945 A
03-09-2005 05:44:54
 Re: concrete recipe in reply to Galen, 03-08-2005 19:45:54
Bagged concrete mix (80#) will yield .6 cu.ft. per bag, NOT 2-3 cu.ft. We bag the product here at our plant. We also bag a concrete mix using lightweight aggregate that will yield a true cu. ft. per bag (80#).
As far as concrete required to cover an area, all dimensions should be in feet, so the formula would actually be length X width X depth, in this case 4" or .33 ft. Divide the resulting number by 27, which would result in cubic yards required for a project. It"s also good practice to "round up" for irregularities.
upred
03-08-2005 17:25:11
according to my Handy Man in Your Pocket book a 94lb bag of portland cement equals one cubic foot. Take the length times width of your project round up to nearest foot and divide by 27 this will give you a good idea of cubic yards of concrete you will need. note that the volume of the concrete mixture is appx 2/3 the volume of the original cement aggregrate mixture, due to the cement and sand fill in the voids in the aggregate. hth - rick
upred
03-09-2005 05:15:55
 Re: concrete recipe in reply to upred, 03-08-2005 17:25:11
I just wanted to clairify - a 94# bag is equal to 1 cubic foot not that it will only cover 1 cubic foot - Rick
