Tool Talk Discussion Forum
fence clips on T posts
doorman
03-08-2005 16:27:15
I'm sure I'm not the first to do this, but I discovered that a 3\16 socketdriver (I used "Craftsman") will fit over the ends of the clips making them very easy to tie barbed wire to the "T" post. Unfortunatly this tool is too long for 2"x4" welded wire, but I'm thinking about how to make a shorter version. Hope this will help someone. doorman
Matt Smith
03-09-2005 05:24:49
 Re: fence clips on T posts in reply to doorman, 03-08-2005 16:27:15
I just use a philips head screwdriver.
TomWNC
03-08-2005 20:44:03
I don"t use the welded wire but I took a scrape of steel about 1/2" x 4" and drilled a hole slightly larger than the wire the clips are made of and it works great. Drill the hole close to one edge. Have thought about using a small steel rod and flatening the end then drill hole. Of course Tractor Supply sells one for about 4 or 5 bucks.
