Tool Talk Discussion Forum
Fence Charger needs help
Grubb
03-08-2005 05:39:44
Went out to check the horses this morning and noticed that my fence charger was"nt pulsing. It was hot but just had a constant light instead of a flashing light. Is it getting ready to go out? How do you go about repairing them?
txblu
03-09-2005 07:15:02
 Re: Fence Charger needs help in reply to Grubb, 03-08-2005 05:39:44
I tried the external trouble shooting on mine (mentioned) and no help. I opened it up and found corrosion all over everything (caused by ozone generated by the high voltage ionizing the surrounding air).
I cleaned the terminals and re soldered the ones that had corroded open then covered the whole thing with a thick layer of WD-40. Used if for about 10 years after that and had no more problems.
Mark
FarmerDave
03-08-2005 19:46:01
Mine, Gallagher, quits flashing when it's shorted out. Unplug it. Disconnect the hot wire from the charger but leave the ground on. NOw plug it back in. If it is flashing again - you got hard short to ground.
IH2444
03-08-2005 07:42:29
If it has a round thing that plugs into it you coule try replacing that. Otherwise, back to the manufacturer for repair or just get another one.
