Tool Talk Discussion Forum
Trenching
George in Bilox
03-07-2005 07:03:32
Hello,
A couple few years ago (I think) a fella here was talking about making up a plough on a three point to trench out to a pond for drainage, said it worked real good with a few passes. I need to trench 6 - 12" deep for some 1/2 water pipe and 2" pipe for underground wire. Any one have plans to make one? Would a middle buster work for this?
Mac
03-08-2005 08:47:44
 Re: Trenching in reply to George in Biloxi, 03-07-2005 07:03:32
Trouble with a middlebuster is it won't throw dirt out of trench once you get very deep. A single bottom or multibottom with all but one tripped/removed will do better job. For drainage, I'd disc a strip and contour a swale with backblade, then plant with grass for erosion. There won't be an unsightly ditch to get vehicle etc stuck in and wide shallow will carry more water than narrow deep. You can pull PVC with a cap, eyebolt and fender washer attached to bottom of a subsoiler with chain etc. Stop and add 20' sections before it dissapears in ground. Beauty of these is no backfill. Here's a subsoiler poly pipe layer also.
ShepFL
03-07-2005 11:21:44
In an emergency I have used a 2 bottom plow. I have shortened the top link all the way up. This tilts the plow on its nose, from this position you can run the trench. A few passes and it should be sufficient depth unless you live in the Northern Tier.
Steve (Magnolia, TX)
03-07-2005 09:53:05
I can't speak, from experience, as to how well it will work, but I've heard from others (on this board as well as other boards) that a middle-buster works well for trenching...
When I can afford to buy one, I plan on getting one, for that very purpose....
HTH
Steve
George in Biloxi
03-07-2005 10:31:23
 Re: Trenching in reply to Steve (Magnolia, TX), 03-07-2005 09:53:05
I just called a place called Poplarville sales and they get $203.00 for a heavy built Fred Cain sub soiler and a 15" middle buster blade is about $30.00.
03-07-2005 10:33:05
 Re: Trenching in reply to George in Biloxi, 03-07-2005 10:31:23
Well, I know that Tractor Supply, around here, sells a King Kutter middle-buster for $100. I've seen them go, used, at auctions for as little as $25 (of course, that was before I decided that I "needed" one)...
Steve
George in Biloxi
03-07-2005 11:58:14
 Re: Trenching in reply to Steve (Magnolia, TX), 03-07-2005 10:33:05
I have seen them too. I do not think they are built heavy enough and hitting a root or something will bend them to he**. Here is a pic of a Fred Cain sub soiler model. And you can put a middle buster blade on it and have both. Fred Cain makes some good stuff, their landscape rake is way better than Bush Hog and I have many Bush hog brand items, I just evaluate the best bang for the buck and do not mind spending more for good stuff that I will have form many moons.
Thanks for the input y'all.
Pitch
03-07-2005 17:46:07
 Re: Trenching in reply to George in Biloxi, 03-07-2005 11:58:14
I have a king Kutter middle buster and I have used it for trenching for cable. won't go deep enough for water pipe but will do 6 to 10" no problem. I suppose you could bend it up if you were doing something dumb like pulling it with a 80 horse tractor but if you use the 40 or less that they are rated for there is no problem. I tacked a hunk of bush hog blade to my upright shaft and cut every reasonable root I hit pulling it with a 23 horse 8n.
George in B.
03-08-2005 06:19:05
 Re: Trenching in reply to Pitch, 03-07-2005 17:46:07
I have a 4000 52 HP. My 9N is temporarily out of commission.
George in Biloxi
03-07-2005 11:59:23
Do not know where the URL went to.
http://www.farmequipmentunlimited.com/greensimplement/fc.htm
