Sounds like an 80 gal vertical tank, five horse two stage. I'm sure Rodger P will chime in with the best of the info on this, but I'll throw out what I can too. To me, 10 minutes sounds like way too much, but this is something Rodger has a better feel for. Emglo was acquired by DeWalt. This may significantly change the parts availability issue for these fine old American built machines. If you have the unit running I assume you have a magnetic starter mounted on it already and are just asking about a wall mounted shutoff switch. You can use just about anything with a 30 amp or better rating. (never exceed 80% of rated capacity for continous operation, so a switch rated at 20 amps is not enough for a steady 17 amp draw). Many switches and disconnects have a hp rating on the data plate, be sure and respect this, if it doesn't go as high as 5 hp, don't use it. You could use the simple old grey box with fuses and a pull switch on the side, something like an ourside disconnect box for a central air system, or anything one of several other switches that would do the trick. Link Select page 342 and 340. You probably should consult an electrician on this to be assured on having wiring, circuit protection and a switch/disconnect that conform to code (for safety, fire protection, and insurance purposes, not to mention peace of mind). Charles
