PTO Driven AC Generators
Lee
11-06-1998 06:46:20
In the 1960's our dairy farmer neighbors had a pto driven ac generator. When the storms would knock out the power, they would hitch up the generator to their 4020, plug into a box on the power pole, throw the cutout switch and be back in business. The cutout switch ensured that no electricity could get on the commercial lines which would be dangerous to the crews. Do they still sell pto powered generators today? Or does anyone still have an old working unit?
BILL
11-07-1998 08:36:59
 Re: PTO Driven AC Generators in reply to Lee, 11-06-1998 06:46:20
: In the 1960's our dairy farmer neighbors had a pto driven ac generator. When the storms would knock out the power, they would hitch up the generator to their 4020, plug into a box on the power pole, throw the cutout switch and be back in business. The cutout switch ensured that no electricity could get on the commercial lines which would be dangerous to the crews. Do they still sell pto powered generators today? Or does anyone still have an old working unit?
YES THEY SURE DO + YOU CAN PICK ONE UP AT AN AUCTION I GOT ONE FOR 200 BUT THEY USUALY RUN A LOT MORE THAN THAT I CAUGHT EVERY ONE SLEEPING ON THAT ONE WHICH DOESENT HAPPEN VERRY OFTEN
Lee
11-07-1998 09:15:43
 Re: Re: PTO Driven AC Generators in reply to BILL, 11-07-1998 08:36:59
: Bill, how much power does your generator need? Would my JD 60 be big enough?
: : In the 1960's our dairy farmer neighbors had a pto driven ac generator. When the storms would knock out the power, they would hitch up the generator to their 4020, plug into a box on the power pole, throw the cutout switch and be back in business. The cutout switch ensured that no electricity could get on the commercial lines which would be dangerous to the crews. Do they still sell pto powered generators today? Or does anyone still have an old working unit?
: YES THEY SURE DO + YOU CAN PICK ONE UP AT AN AUCTION I GOT ONE FOR 200 BUT THEY USUALY RUN A LOT MORE THAN THAT I CAUGHT EVERY ONE SLEEPING ON THAT ONE WHICH DOESENT HAPPEN VERRY OFTEN
bill
11-09-1998 08:38:57
 Re: Re: Re: PTO Driven AC Generators in reply to Lee, 11-07-1998 09:15:43
: : Bill, how much power does your generator need? Would my JD 60 be big enough?
: : : In the 1960's our dairy farmer neighbors had a pto driven ac generator. When the storms would knock out the power, they would hitch up the generator to their 4020, plug into a box on the power pole, throw the cutout switch and be back in business. The cutout switch ensured that no electricity could get on the commercial lines which would be dangerous to the crews. Do they still sell pto powered generators today? Or does anyone still have an old working unit?
: : YES THEY SURE DO + YOU CAN PICK ONE UP AT AN AUCTION I GOT ONE FOR 200 BUT THEY USUALY RUN A LOT MORE THAN THAT I CAUGHT EVERY ONE SLEEPING ON THAT ONE WHICH DOESENT HAPPEN VERRY OFTEN
lee
we run ours with a compact j d 1050 rated at 33 h p it has plent of stuff but it depends on what you are running with it if you just run a saw off of it you could do it with an h but if yourun a machine shop off of it you will need 100 h p normaly your 60 at 37 h p would be plenty also there are larger generators that take more h p any more questions i will try to answer them for you or you can e mail me
Dusty
11-10-1998 17:40:53
 Re: Re: Re: Re: PTO Driven AC Generators in reply to bill, 11-09-1998 08:38:57
: : : : Bill, how much power does your generator need? Would my JD 60 be big enough?
: : : : In the 1960's our dairy farmer neighbors had a pto driven ac generator. When the storms would knock out the power, they would hitch up the generator to their 4020, plug into a box on the power pole, throw the cutout switch and be back in business. The cutout switch ensured that no electricity could get on the commercial lines which would be dangerous to the crews. Do they still sell pto powered generators today? Or does anyone still have an old working unit?
: : : YES THEY SURE DO + YOU CAN PICK ONE UP AT AN AUCTION I GOT ONE FOR 200 BUT THEY USUALY RUN A LOT MORE THAN THAT I CAUGHT EVERY ONE SLEEPING ON THAT ONE WHICH DOESENT HAPPEN VERRY OFTEN
: lee
: we run ours with a compact j d 1050 rated at 33 h p it has plent of stuff but it depends on what you are running with it if you just run a saw off of it you could do it with an h but if yourun a machine shop off of it you will need 100 h p normaly your 60 at 37 h p would be plenty also there are larger generators that take more h p any more questions i will try to answer them for you or you can e mail me
A 25 KW will put out 104 amps. @ 240 volts, and will requier 45 hp. Cost $2000 t0 $3000.
Not cheap, and this does not include the transfer switch.
Good luck,
Dusty
