Tool Talk Discussion Forum
Tech Question
PJW
03-05-2005 12:08:31
Hi Guys, Needs some help. I had a special machine built that has pneumatic grippers on it. Having problems with the grippers holding too hard. The gripper cylinders are SMC and have a rating of 0.1- 0.6 MPa. Is this a metric rating or what? Stuck at work this weekend to solve the problem and cannot get a hold of the machine builder or cylinder supplier. Please help!
buickanddeere
03-06-2005 13:27:42
 Re: Tech Question in reply to PJW, 03-05-2005 12:08:31
>Link
>Link DaveinCa is correct on his calculations
Simply splendid conversio
03-07-2005 12:03:08
 Re: Tech Question in reply to buickanddeere, 03-06-2005 13:27:42
I have to say something about this Omnicon pgm. I had some serious PC trouble some time ago. I thought it was related to this pgm and this Jones fellow did everything possible to help. Turned out it was another pgm giving the trouble.
Omnicon has always worked excellent.
Funny the software that works the worst are the one's you hear the most about.
Chris(WA)
03-06-2005 06:25:44
Gripping too hard is not usually a cylinder problem. More likely a problem with the regulator controlling air pressure TO the cylinder or a select function of the controller or valves (selecting high pressure when you need low or stuck on high) that operate the cylinder.
DaveCA
03-05-2005 22:21:28
0.1 - 0.6 MPa = 14.5 - 87.0 psi
Midwest redneck
03-05-2005 17:13:14
My dad worked for SMC Pneumatics for 22 years, he retired last year...he was in sales. Mpa stands for Millapascals I think. If you need help call Sunsource in Madison Heights Mi. their # is 248-585-5252. Sunsource is a SMC distributor.
PJW
03-06-2005 05:35:07
 Re: Tech Question in reply to Midwest redneck, 03-05-2005 17:13:14
Thanks guys, I was able to find the cross reference but like usual the answer is posted here as well!
Hey Midwest From some of your postings it sounds like we are from the same area of the country and related trade. I have used Sunsource in the past when they were called Faulver, may even know your father. I did place some calls to the supplier but since it was late Saturday could not reach anyone. To solve my machine problem I believe I need mini regulators. The machine has other pneumatic circuits that require high air pressure but the end tooling (grippers) could work with much less. Found the SMC catalog on the net and it looks like they have what I need. Likely I will be calling Sunsource Monday morning.
From some of your other posts I gathered you are a toolmaker. I started out in the tool trade several years ago and served an apprenticeship at a tool shop in Sterling Heights. It is a shame what has happen in Michigan with all the tool shops. The free trade really worked good for our part of the country! The state is broke and has the highest unemployment in the country! Well as long as the politicians have their medical coverage and retirement packages I guess that�s all that maters!
Midwest redneck
03-06-2005 13:03:49
 Re: Tech Question in reply to PJW, 03-06-2005 05:35:07
What company do you work for? I live in North Oakland county. I work in Troy. Yeah, Michigans economy is for %hit right now but it is sloooowly coming back. What shop did you work at in Sterling Heights?
Charles (in GA)
03-05-2005 13:06:55
MPa is Megapascal. According to my unit converter on my Palm, 1 MPa equals 145.0377377 psi.
1 psi equals 6.8947573e-3 MPa.
Hope this helps.
Charles
jackal5
03-06-2005 16:56:08
 Re: Tech Question in reply to Charles (in GA), 03-05-2005 13:06:55
1 atm = 14.7 psia, 1 atm = 101325 Pa = 0.101325 MPa
1 psia = 101325/14.7 = 6892.86 Pa = 6.893x10^-3Mpa
