Tool Talk Discussion Forum
Homelite Super 2 chainsaw - missing part
DRM58Y
03-04-2005 17:18:40
I have a homelite super 2 chainsaw and it is missing something between the plastic "trigger" in the handle and the spring loaded "eylet" on the throttle of the carburettor. Nothing appears to be broken. The plastic handle trigger action moves a lever with a small hole in the end located above the carburettor in a front to back motion The throttle lever on the carburettor is spring loaded and moves in an obscure up down motion.
I assume what I"m after is a piece of wire bent in a few places).
An exploded view of the parts would be great so I could make something or else knowing where I could obtain a spare part would be great.
bobcaterdon
03-05-2005 21:04:39
 Re: Homelite Super 2 chainsaw - missing part in reply to DRM58Y, 03-04-2005 17:18:40
Her is another site you could go to for information Don
http://www.acresinternet.com/cscc.nsf?OpenDatabase
NC Wayne
03-05-2005 19:51:18
Try this link, somebody listed should be able to help you out with a diagram as well as the part needed.
Vintage Homelite
03-06-2005 22:01:55
 Re: Homelite Super 2 chainsaw - missing part in reply to NC Wayne, 03-05-2005 19:51:18
What you need is either P/N 69255A Rod or 00138 Rod or 02501 Rod. Which one depends on the age of your saw.
The UT# is the surest way to get the correct one.
Email me your phone # ... I stock most of parts you may need
Thanks
Bill
Servicing HOMELITE for over 50 years.
