Tool Talk Discussion Forum
diesel injector tool?
vabill
03-04-2005 07:27:19
i have to replace my cyl. head on my diesel tractor, a friend is going to put in the valves. he said i need a tool to put in the injectors. is their such a tool or do they just push in. bill
Bernard le m�cano
03-04-2005 11:30:35
 Re: diesel injector tool? in reply to vabill, 03-04-2005 07:27:19
Hi vabill, carefully clean the hole, injector tip and seat with a brush. Push the injector, by hand, in the hole and secure with the clamp. If you change the tip for a new, you may have to adjust the openning pressure with a test pump. Bernard le m�cano Qu�bec Canada
Ron F.
03-04-2005 08:10:11
We need more info to help you on this!! Make and model of tractor. type of injectors.
vabill
03-04-2005 09:22:54
 Re: diesel injector tool? in reply to Ron F., 03-04-2005 08:10:11
its a case/ih model 385, 3 cyl, diesel, 35 hp. do you need anything else?. bill
the tractor vet
03-04-2005 09:41:43
 Re: diesel injector tool? in reply to vabill, 03-04-2005 09:22:54
Yep , if you are replacing the injector well ya need the tool . I don't have one i would barrow one from the I H dealer if i was replacing a well or tube however ya want to call it .
