Tool Talk Discussion Forum
Formula to determine pulley size?
Jack B. Nimble
03-04-2005 07:08:04
I am trying to figure out what size pulleys I need to achieve the correct shaft RPM. I Know the motor RPM and the pulley size that is on it but what is the formula to figure out what size driven pulley to use to get X RPM on the driven shaft? Help!
Irv
03-04-2005 22:44:04
 Re: Formula to determine pulley size? in reply to Jack B. Nimble, 03-04-2005 07:08:04
Get a Machinist handbook. It has all the formulas and applications. Irv
JL Sargent
03-04-2005 07:27:40
I found this in a post from some time ago. I think It will answer your question.
"To determine the size of driven pulley
to obtain a required speed of a driven shaft:
Multiply diameter of driving pulley by
number of revolutions per minute and divide by
desired speed of driven shaft in rev per minute"
Bob
03-04-2005 07:26:22
Motor RPM's X pulley size / desired RPM's of driven shaft.
That will get you very close. Knowing the "pitch diameter" of the pulleys would get you even closer.
