Tool Talk Discussion Forum
Torque wrench and extentions
Morty-Alberta
03-01-2005 14:40:46
I think I know the answer to this but... Does using extentions on a torque wrench change the reading at all ? I am referring to between the wrench and the socket not a cheater.
Nolan
03-04-2005 04:13:42
 Re: Torque wrench and extentions in reply to Morty-Alberta, 03-01-2005 14:40:46
When using a torque wrench to tighten down a fitting, it won't make any difference. Yes, it does twist, but the torque is still applied to the nut.
Now when it comes to using a breaker bar or an impact wrench to take the fitting off, it does make a difference. The twisting that takes place along the extension dampens the sharp applications of force, reducing the effectiveness at getting the nut to break free.
Boog
03-03-2005 09:40:14
Joe (Wa) said, "The reason is you are expending effort keeping the wrench and longer extension straight enough to apply torque. In engineering terms that is called lateral shift. All the input force is not being applied to the fastner."
This is correct. In theory, no loss with an extention; in practice noticeable loss from extention not able to be kept in direct alignment with longitudianl axis of bolt AND shaft flex.
Can't even use my name
03-06-2005 06:03:05
 Re: Torque wrench and extentions in reply to Boog, 03-03-2005 09:40:14
That was my point, what should work usually never does in the real world. Now, can we explain why you lose torque using an extension on an impact wrench? Because you do regardless of the fact you shouldn't.
Joe (Wa)
03-02-2005 18:19:54
As long as there is no offset, torque out is equal to torque in. The extension can be any length, made out of high carbon steel or wet noddles, makes no difference whatever.
For offset like crowsfoot there are compensation tables. A search should find some on the web.
Joe
03-02-2005 19:13:45
 Re: Torque wrench and extentions in reply to Joe (Wa), 03-02-2005 18:19:54
I realize that in theory the force applied to one end of an extension should be equal to the force at the other end but I have been on the farm long enough to know that in the real world that isn't quite true. I have tried to loosen many lugs where a long extension made it easier to get the breaker bar on and couldn't budge em, put on a shorter bar or no bar and somehow they tend to come loose. And if torque applied in is equal to torque out then the reply about a constant force not losing torque but a jerking or impacting force would doens't make any sense. Again, theory is one thing but the real world is a whole different game.
Joe (Wa)
03-02-2005 21:16:31
 Re: Torque wrench and extentions in reply to Can't even use my name, 03-02-2005 19:13:45
Joe
Opa A
03-02-2005 20:31:42
If jerky or impact forces do not affect the actual applied force on a fastner then why do the instruction booklets that came with all my MAC and Snap-On torque wrenches say to, quote "turn the fastener down with a smooth and even force"? Garett
Joe (Wa)
03-02-2005 21:21:41
 Re: Torque wrench and extentions in reply to Opa A, 03-02-2005 20:31:42
Why don't you think about that some. If you've done any wrench pulling, I am sure you can answer your own question.
Joe
Opa A
03-03-2005 09:15:49
 Re: Torque wrench and extentions in reply to Joe (Wa), 03-02-2005 21:21:41
Hi Joe.
I agree with all of your statements previous. I've been pulling wrenches for a living for the last 20 years, and do know the answer to my question. I was more interested in what "Can't even use my name" has for an explanation.
Garett
Joe (Wa)
03-03-2005 12:25:11
 Re: Torque wrench and extentions in reply to Opa A, 03-03-2005 09:15:49
Garett,
My first post above was in response to the initial question. Now that I�ve read all the posts it appears to have gravitated somewhat to impact torque. I know practically nothing about that subject.
My response to your post was inappropriate, in fact, sounds like it was make by a Jack@$$. I owe you an apology and this is it.
Joe
Opa A
03-03-2005 17:53:07
 Re: Torque wrench and extentions in reply to Joe (Wa), 03-03-2005 12:25:11
Joe
No problem, hey thats what these forums are for, discussion
Garett
Opa A
03-02-2005 15:51:14
The way I see it is the only thing keeping the extension from turning is the resistance of the fastener that the socket is on. The extension could be 40 feet long and the same would still hold true. So no, an extension does not change the torque.
The difference is when the torque is not applied in a steady manner, such as with an impact or jerking on whatever handle is used. In this situation the recoil or flex in the extension would distort or lessen the torque at the fastner. That is how the torque bars for wheel lugs work, with an impact but not with steady pressure.
My 2C
NEsota
03-01-2005 21:00:51
Will even use my moniker, I agree with Russ Smart and Farmall_Ryan.
Charles (in GA)
03-01-2005 20:09:38
A little off the topic but thought this was cute.
I can only speculate what the company name really means..... ..
Link
Charles
big jt
03-01-2005 22:32:00
 Re: Torque wrench and extentions in reply to Charles (in GA), 03-01-2005 20:09:38
Thats quite a outfit.
I am sure they just give those set ups away LOL
jt
Farmall_Ryan
03-01-2005 16:37:10
Nope
Extensions don't have an effect on torque reading.
03-01-2005 18:25:59
 Re: Torque wrench and extentions in reply to Farmall_Ryan, 03-01-2005 16:37:10
Are you sure? I know many times I have tried to loosen a lug nut or other stuck nut with an extension and couldn't budge it, take off the extension and it will come loose. Noticed the same thing with the impact too.
Russ Smart
03-01-2005 19:17:54
 Re: Torque wrench and extentions in reply to Can't even use my name, 03-01-2005 18:25:59
An extension should not effect torque on a torque wrench but it will give it some springiness, on an impact it will, because the torque is created by impact, not true twisting torque.
Farmall_Ryan
03-01-2005 19:14:55
An extension shouldn't effect the torque assuming its a high quality steel with very little torsional flex and the torque you are tightening to is not extremely high.
With a very high torque, or a very long extension, or very cheap metal, the extension could in theory decrease the torque seen at the socket end.
Again, with any average torque values and with standard size extensions, it shouldn't have enough effect to be noticeable.
Davis In SC
03-01-2005 19:05:16
Long extensions do seem to absorb some of the torque from an impact wrench. After all they do make the "Torque Sticks" that are supposed to limit the amount of torque to a certain level. I think that is the reason that Swench extensions are made in the shape of a tube, so impact is not lost.
Charles (in GA)
03-01-2005 16:37:09
A straight extension, like used to reach into a recessed area?
In theory, no it should have no affect on the torque. In practice, it could affect the torque as the extension may have some spring or torsion to it. I would not get overly concerned about this however.
If you are using offsets, you must compute the proper torque reading for the offset. A new torque wrench will come with information on this.
Charles
