Tool Talk Discussion Forum
2 3 Inch Sanding disc Types
dave2pa
03-01-2005 08:58:57
hello
have been thinking about getting some of these small sanding disc but i see there are different types some have a plastic screw and asome have a hole on the back ?? what is the best type ??local autobody store wanted 16 bucks just for the mandrel ,wanted to make sure i get the right one . Want to use it in a 1/4 air drill,mainly want to smooth weld splatter and to smooth edges during fabrication Thanks
Dave
ArtinNY
03-01-2005 11:52:16
 Re: 2 3 Inch Sanding disc Types in reply to dave2pa, 03-01-2005 08:58:57
You should check out any Industrial supply houses in your area. Around here the industrial supplies are a lot cheaper than the automotive sources for the same products. WWW.3m.com go to "pruducts & services" after you pick a product the next page will have a link labeled "where to buy". Just follow the directions and they'll tell you where you can purchase thier products. $16.00 is too high.
Rod (NH)
03-01-2005 10:20:22
Hi Dave,
I prefer the 3M "Roloc" system with the plastic screw on the back:
third party image
The 3M system is flexible in that there are things other than sanding discs that go in the same mandrels. For example, "Scotch-Brite" surface conditioning discs and "Bristle Discs" (which are like a mild wire brush). Everything is available in 2" and 3" (you should have both mandrels - each with the correct size backing pad). They do tend to be a little on the pricey side but they work very well. They can be used in an electric drill but a higher speed pneumatic die grinder works best.
third party image Rod
