Tool Talk Discussion Forum
OT: Attic/whole house fan
HobbyFarmerInWI
03-01-2005 04:36:05
Does anyone have any feedback on the motorized fans you install in 2nd story ceiling to draw hot air up from living area and out through the attic?
I have seen large and small ones. The large ones say they will cool faster, the smaller ones saying they are quiet.
What do you all think about them?
Nolan
03-02-2005 05:45:04
 Re: OT: Attic/whole house fan in reply to HobbyFarmerInWI, 03-01-2005 04:36:05
Consider carefully where you put the fan and how the resulting air flow will work with it.
Friends installed one that draws through the bathroom. The idea sounded nice, but causes a wee bit of a problem when you try to close the bathroom door. It ripped the solid door apart, and trying to close replacement slatted door is still hard. Not to mention bathroom use is none to private with that slatted door.
MarkB_MI
03-01-2005 17:12:21
I had one in a beach cottage I owned in North Carolina. I had to go with a small unit because of the fan location. It worked very well, but did make quite a racket. I always assumed the bigger ones would be quieter.
leland
03-01-2005 15:35:52
Wifes uncle installed one and it works great at first he thought it was broken then he realized that you needed to have a couple of windows open DA
Nicklan
03-01-2005 13:32:50
I have had them, depending on condtions they can pull alot of dust and pollen in. Stick if you have allergies. Otherwise many small openings seem to be better.
wisdave
03-01-2005 08:56:51
I have had a whole house fan for four years and love it. It is a two speed, and large. With these fans volume is everything..get the larger one. Those nights when there is no breeze or you just want to move some air the fans are just the ticket. Good Luck.
Ron from IL
03-01-2005 07:15:13
Here's what I did:
I really dislike the noise of a propeller-type attic fan, so I used a large squirrel-cage fan from a heating/cooling system. You can often get them used from an HVAC/R company. I mounted twos sets of motorized louvers (available from Grainger campany) in the ceiling of the 2nd floor where the fan would normally be mounted. I then mounted a second set of louvers on the gable end of the attic and suspended the squirrel-cage fan in front of it. You have to make a "boot" from the front of the fan to the louvers to keep the air directed to them. The fan was hanged from chains and springs suspended fron the rafters, which isolates the house fron vibration and noise.
The fan set-up is a little more complicated to install than a normal attic fan, but you will thank yourself for doing it this way. It is VERY quiet, and almost maintenance-free.
Good luck!
Ron
greenbeanman in Kansas
03-01-2005 07:13:41
I have installled two into different homes I've owned.
The belt drive units are the better choice.
Get the largest unit available, hopefully rated at several times the square footage of your home.
Be aware that they need to be installed horizontally which is logical anyway. The bearings aren't suited for verticle mount.
I prefer to open windows a couple of inches in the far corners of my home to exhaust the warm and or humid air from all parts of the house. Opening one window wide open doesn't feel like you are getting any air flow.
Make sure your exhaust vents remain clean if they are screened.
I also recommend that you put a timer on the fan switch. Wonderful to cool the house down at bedtime without having to get up in the night to shut it off. Sometimes it just gets too cool if left on.
I haven't used an air-conditioner at home since 1997, relying solely on the attic fan instead---well also the neighbor's swimming pool.
MAC,IL
03-01-2005 06:24:13
Works great. BUT watch the speed after installation. If you do not have enough exhaust outlet, some of the air will be blown back into the area below the fan. I prefer a larger fan with less RPM.
Ralph, Ohio
03-01-2005 05:25:19
I have such a fan with shutters in the ceiling of the attached garage on my one story ranch style house. On hot summer evenings I close the overhead garage door, open the door from house to garage, open the bedroom windows in the other end of the house, and draw outside air through the house and out the attic. Having the fan in the garage eliminates problems with dirt, bugs, or cold air coming down throught the shutters when the fan is not in use. If I just want to cool the attic I can leave the big garage door open and run the fan.
My fan blade is mounted directly to the motor shaft while the better ones I believe are belt driven. I'm not sure of the pros and cons but I have the impression the belt drive units may run slower and thus be quieter even at full speed. Be sure to get one with a variable speed control.
