I urgently needed 1500 lineal feet of 10' pine studs this winter, so I had a guy cut them and in late October I piled them in the abandoned horsestable with doors open for cross-ventilation. It turns out a below-ground-level horsestable is a bad place to dry lumber. By Christmas several layers of studs were stuck together with interesting greenish blue and white fungi. I quarrantined the worst of the moss on an unused hayrack in the middle of a windy field. The rest I moved into the semi-heated stone house where they were needed. Stickered in the sudden heat, they lost moisture quite admirably, helped by a large household fan. The moss remnants gave up immediately, but the 2X4's which were inclined to warp certainly did so. This was no big deal to me because for studding in a stone house all I needed was one true surface so I'd trim them to length, then straighten the studs on the jointer. The pine has dried quite a bit, and the trued studs have held their positions. For anything important, though, I'll stick with wood air-dried outside for a year or two, then inside for the rest of the three years per inch. The other rule is to move the wood into the room where it will be used for for three weeks prior to cutting. I've had reasonable luck in late fall with pine dried in the wind for a summer, but I certainly wouldn't try it with oak. I need flooring, so in next week I'll start looking for piles of boards left over from cuttings a few years ago. This is where persuasion and even guile enter the craftsman's toolbox. Good luck with your renovations. Rod
