Tool Talk Discussion Forum
Compressor question
Jay87T
02-27-2005 05:07:17
my question is, are the compressor pumps directinoal? and if so what direction do they pump? clockwise or counter? If I were looking at the pulley face on. reson I ask is when I went to look at this compressor the guy had his leads on wrong hooked up to the motor and I think it was spinning the wrong way.
Roger P.
02-27-2005 09:56:48
 Re: Compressor question in reply to Jay87T, 02-27-2005 05:07:17
Most compressors are not directional, except for the cooling fins on the flywheel, which will not blow cooling air onto the pump if it is spinning backwards. This does not apply to some pressure lubricated compressors (Quincys) where the opposite rotation can prevent the oil pump from producing oil pressure. On some Quincys with a gerotor oil pump, the rear bearing carrier must be spun 180 degrees, and a pipe plug must be switched around with the pressure gauge. Other Quincys adjust automatically, as do Dressers and others. These usually have vane type oil pumps.
dr.sportster
02-27-2005 06:08:22
If its single phase incoming leads cant reverse it .You must change splices in the peckerhead to reverse it.
Coloken
02-27-2005 06:03:17
Some compressors have an arrow showing direction cast in the pulley/flywheel. If the pulley has like wings (fan blades) as spokes to blow air across the cylinders, it should turn the correct way. Other wise I don't think it matters.
