Tool Talk Discussion Forum
campbell hausfield compressors at Wal Mart
farmweld
02-26-2005 16:47:47
several questions: would a 60 gal, unknown SCFM rating, be able to hold up with a HVLP gun, die grinder, angle grinder, and other small low consumption air tools. wont be running more than one at a time
thanx in advance
farmweld
John *.?-!.* cub owner
02-26-2005 18:52:02
 Re: campbell hausfield compressors at Wal Mart in reply to farmweld, 02-26-2005 16:47:47
I have one of the CH vertical tank compresor they sold as 5 peak horsepower, acturally aobut 2 horsepower. Any one of the tools you have listed will work, but you will have to stop every so often and aloow it to catch up if trying to use continous. Those compressors have a duty cycle (usually about 20 ppercent) that you will have to observe if you don't want to overheat it.
FarmerDave
02-27-2005 14:46:36
 Re: campbell hausfield compressors at Wal Mart in reply to John *.?-!.* cub owner, 02-26-2005 18:52:02
I got a little Dewalt compressor. I found it reconditioned at a Sears outlet, full warranty, special Christmas markdown too. The owner's manual doesn't list the duty cycle. How will I know what it is?
There may be a thermal shutdown on the motor.
farmweld
02-26-2005 17:28:51
sorry. i guess its 20 gal. could i add a seperate storage tank for more run time? 4 SCFM
farmweld
Mike Burdick
02-26-2005 19:16:14
 Re: campbell hausfield compressors at Wal Mart in reply to farmweld, 02-26-2005 17:28:51
Make sure your compressor will deliver the needed SCFM at the rated psi of the most demanding tool you expect to use. Adding additional storage capacity will not help you.
If you have a "undersized" compressor you will never be happy. Spend the money to get the proper size - it"s way cheaper in the long run.
Bernoulli
02-26-2005 17:43:59
Each of your tools should have information about its air consumption. High quality tools generally use less air than cheaper tools of the same purpose. I doubt that compressor would keep up with a HVLP gun.
