Tool Talk Discussion Forum
Two Air Compressors Quincy 325 Devilbiss 432?
JLSargent
02-26-2005 10:23:59
I bought these two compressors yesterday at auction for cheap both with 5hp motors and condition unknow other than they turn freely. How can I check em out, or what should I do before just putting power to em?
JL Sargent
02-27-2005 12:33:25
 Re: Two Air Compressors Quincy 325 Devilbiss 432? in reply to JLSargent, 02-26-2005 10:23:59
432 pump: I removed all valves and as predicted some had broken springs and two others were not seating properly. If new springs can be bought all around I believe it would run properly. Cylinder wall are all good with one LP wall rough at the top but I can scrap it off with finger nail.
325: All valves intact and look good. Only the HP exhaust looks a little rough but spring intact and valve seats. All cylinders smooth. I got one complete gasket off for a template. Im making the gaskets for it today. Whats the procedure for tightening the set screws on the valve covers and torque on the bolts. I have not disassembled the unload which looks kinda rough.
Roger, you mentioned lapping the valves on a piece of flat glass. Can you go into this more? I assume lapping compound and in circular motion. Is this correct?
Thanks for all the help with it.
Roger P.
02-27-2005 13:41:23
 Re: Two Air Compressors Quincy 325 Devilbiss 432? in reply to JL Sargent, 02-27-2005 12:33:25
It is as I suspected it would be. If you are not pumping oil, you are well ahead. Valve springs are readily available for the 432 from any compressor shop. Older DeVilbiss springs were installed with the "concave sides" facing each other, one spring on top of the other. Unfortunately, in this setup, the little "tang" on the inside of the springs were forced to slide up and down with each valve actuation, which often led to them cutting little notches in the cast iron spring guides. DeVair instructs anyone rebuilding valves to place the two springs with their concave surfaces facing in the same direction, sort of like two spoons sitting in each other, with the little tang sitting at the bottom of the guide. The springs can now bend at the very edges, and the tangs stay in place and do no further damage (I hope you can follow that description).
When reinstalling the 432 caps, back off the setscrews in the caps first. Tighten the caps (1 1/2" socket), then tighten the setscrews to press the valves down into their pockets. Excess force is not required, and may snap off the setscrews, which are then a real pain to extract. If these setscrews are seized, heat, penetrating oil and patience are required to get them out. If you break them off while they are seized, you will probably have to scrap the cap. Don't try to reinstall the caps with seized setscrews. I they are in too far,when you install the caps you may put enough force on the valves to crack the cylinder heads or split the valves. When you have the setscrews snugged up, check to see that they are all sitting at the same height. If any are higher than the others, that valve is probably not sitting flat inside the head and will leak air. Reinstall the acorn nuts which cover them. Done!
On the Quincy, the same care must be taken to see that the locking rings and setscrews which do the same job as the setscrews in the 432 are also backed off before torquing down the big square valve cover plates. As long as these are backed off, you can put the cover plates back on and torque them down. Now, turn in the big Allen setscrews on the valves with no unloader towers. Once tight, re-install their cover nuts. Again, just hand-tight will do, no need for a snipe or anything. The unloader towers thread onto a big threaded metal ring, which also serves to retain the valve bodes, again, just like the setcrews mentioned before. There is a special ring-wrench for this, but putting a short length of flat bar in the notches and turning with an adjustable wrench does the trick also. Once tight, you can thread the unloader towers back on by hand, then give them a slight re-torquing with a pipe wrench, or chain wrench. I would recommend taking the unloaders apart to see if the little pucks in the top are seized, or if the rubber diaphragms are rotten. If these are not functioning correctly, you will get no satisfaction from this pump.
As far as lapping goes, I use a 180 grit air sander pad, the kind with the sticky backs, attached to a flat glass plate. A heavy piece of FLAT steel plate will also work, bt it must be very flat. Keep it lubricated with Varsol, or WD40. It shouldn't take very long to get a nice, uniform, bright seat on any of the valves. Figure 8 pattern, of course, and check frequently for uniformity. There should be two nice sharp concentric rings on the faces of the 432 valves. If these are missing, you will have to get them recut on a lathe, a very easy job (a 3 jaw chuck will do nicely).
JL Sargent
02-27-2005 19:12:02
 Re: Two Air Compressors Quincy 325 Devilbiss 432? in reply to Roger P., 02-27-2005 13:41:23
325: As suggested the unloader tower was stuck but with a 2 hr soak in pen fluid and a small plastic hammer it freed up. Diaphram still good. All appears good with it now. Pressing down on black button under diaphram works the valve and returns to position. My homemade gaskets looked good I just hope they seal well. The HP Exh. valve cover seal area either flaked a very thin sliver of metal maybe due to corrosion or metal was added for sealing? I used a pneumatic gasket remover (rubber like wheel with bumps) and really slicked it out. Are you familiar with this situation? Can the seal surfaces flake? Anyway the pump is reassembled and ready for a test run.
432: Im calling around tomorrow for the springs. Can you get a reseal on the copper rings or should I plan on getting those? These hex head set screws break very easily at the socket. There is just enough there to use it.
Roger, with you help I feel like alot has gotten accomplished between my 1yr old son who wants to help and my wife who wants him to. Not to mention the fact that I've gotten to learn something along the way. Heck, it does'nt get much better than this!
Roger P.
02-27-2005 20:23:04
 Re: Two Air Compressors Quincy 325 Devilbiss 432? in reply to JL Sargent, 02-27-2005 19:12:02
Well done JL. Glad to see you are making good progress. The sliver of metal you saw was probably the remains of the aluminum crush ring that goes under the unloader towers and setscrew cover nuts to seal them against the valve cover. I forgot to mention it, sorry. It performs the same function as the copper orings on the 432 valve caps, i.e. it seals air pressure inside the head where it belongs.
Hopefully, the unloaders will cooperate and seal while it's running, and unload when it isn't. Inside the unloader tower, you probably saw a long brass plunger that somewhat resembles a big automotive style engine valve. On the top of the "valve" head, there is an embedded silicone O-ring which seals againts a surface inside the unloader tower. If you hear a constant air leak from the tower exhaust port, you will know that it is not sealing properly (some 325s run a small copper line from this 1/8" NPT port to the intake area, just above the filter so it vents inside the head for quiet unloading, in which case, it might be hard to notice). This could also indicate that there is no oil pressure, and the pump is unloading to try and protect itself from seizing (a very smart feature). If this line is on your pump, you can safely pull it off from the head and listen while it is running. If there is no air coming from it, great. It should give a short blast of air after the compressor shuts down (the compressor is unloading). Depending on the age of your 325, there is either a small hydraulically actuated valve built into the side of the crankcase, or, threaded into the top of the oil pump assembly, which has (or should have) a copper line feeding tank pressure to it. This is the hydraulic unloader valve. It is a simple spring loaded valve with cup seals that closes with oil pressure, and opens when there is no oil pressure. This is why it is important to monitor the oil pressure on the Quincy when you start it up. If there is no oil pressure, this valve will not close. Air will be sent to the unloader towers to hold open the intake valves, and the pump will not produce any air. Obviously, you will then have to remedy the lack of oil pressure before going any further. If oil pressure exists (15-30 psi), and there is still no air being produced, suspect bad seals in the hydraulic unloader valve, or the silicone o-ring I mentioned earlier in the unloader tower. Any of these seals should be readily available from a hydralics supply shop.
About the 432, you can use a long 3/8" UNC bolt and a jam nut to do the job of the setscrew if you break some, but sourcing new ones shouldn't be difficult. I guess you can reuse the rings. Generally I don't recommend it, as they are one use, but for a smoke test I don't think there will be any problem. Teflon tape on the valve cap threads, or pipe dope should work in a pinch. The aluminum crush ring on the 325 will probably have to be replaced though.
It is probably a little late to mention this, but a good dose of anti-sieze is recommended on all the setscrews on both compressors, and especially on the 432 valve caps.
Sound like these compressors were scrapped due to general neglect of a few easily remedied problems. Certainly good news for you! Don't forget to install the 60 psi safety valves (1/4" NPT)in the interstage coolers of the 432 and at the top front of the head on the 325. You will not know if you have bad valves otherwise, unless you take interstage pressure readings.
Roger P.
02-26-2005 13:44:34
First thing I'd do is make sure the tanks are not ready to blow. A hydrotest would be a great idea. Some have suggested filling the tanks with water as full as possible, then installing a grease zerk in a fitting and pumping the tank up to whatever pressure you feel indicates that it is sound. I've never done this, but the idea seems logical, if you can get all the air pockets out of the tank.
Second thing I would do is put a megger on the motors to see if the windings were good before I put any power into them. Third, I'd change the oil. Fourth, I'd make sure the Quincy was priming its oil pump by making sure the oil pressure gauge was installed and working. The 432 is pretty self contained. It was nigh impossible to destroy either of these old pumps, and both are readily rebuilt, and worth rebuilding. Each pump is worth a couple of grand new.
Listen for any knocks while they run (obviously). There should be a 70 psi safety relief valve in both of the interstage coolers on the 432, and there should be one in the cylinder head of the 325, just above te interstage tube. If any of these pop while the compressors are running, you have bad valves in the HP cylinder(s). If they do not pop, take each one out, one by one, and run them with a pressure gauge installed. You should get between 20-40 psi (this is just a rule of thumb). If they are much lower than this, or zero, you have bad valves in the LP cylinder(s). If the safety valves are missing altogether, the pumps probably have bad valves, and someone in the past pulled the "failed" safety valve to get the compressor running again. Even if the compressors seem to run ok, I'd still pull the valves and have a look at them. DeVilbiss compressors can run even when they have broken valve springs. You can tell this, with experience, as they tend to be rather "clicky" while running. This can lead to sharp bits of spring going into the cylinders, which can lead to broken valve seats, broken piston crowns and maybe even a broken rod if the bits get wedged between the piston crown and cylinder head. The 325 valves are less trouble, but can suffer greatly from carbonization if the wrong oil was used, or if the compressor was passing a lot of oil. Pulling the valves isn't a big job, and can save you a bit of grief. Yo may have to make yourself some gaskets, but they aren't too hard to make. Just remember, if you do pull the valves, back off the hex setscrews under the acorn nuts on the valve caps of the 432, and back off the setscrews and rings under the big nuts and unloader towers on the 325. These put tension on the valves to hold them in place when assembled, and if they protrude too far in during reassembly, you can damage the head or valve bodies by putting too much compression force on them.
JL Sargent
02-26-2005 19:02:57
 Re: Two Air Compressors Quincy 325 Devilbiss 432? in reply to Roger P., 02-26-2005 13:44:34
Thanks so much. There is not a pressure relief valve on either one unfortunately which makes me wonder if the HP valves are knocked out on both pumps. I dont have a megger but I did verify the motor legs are not shorted to ground or each other. I will change the oil on both. Can I make the gaskets out of regular gasket material or do I need something special? Tank integrity appears good on both. On the quincy doesnt the valves and seats come out in a package? Is the 432 like this too? If I can only rebuild one which one would you do based on quality? Thanks again.
Roger P.
02-26-2005 19:53:58
 Re: Two Air Compressors Quincy 325 Devilbiss 432? in reply to JL Sargent, 02-26-2005 19:02:57
The gaskets are nothing special, but the valve caps on the 432 have copper orings which seal them. This could be a problem if you don't have a ready supply of them, although you can probably get away with teflon taping the threads. The valves in both compressors come out as an assembly. The Quincy has four massive cast-iron valve castings with springs, plungers, discs and bolts. They are really overbuilt and last forever, unless a wayward spring has broken up and landed across the seat area. The DeVilbiss has 8 separate brass valves, with discs and springs. They too last a long time, and can be readily reshaped on a lathe if the valve faces are flattened out. A good hand lapping with compound on a flat surface like a thick sheet of glass does them a world of good. The DeVilbiss valve springs are a bit of a weak point. They are just two bowed pieces of spring steel which lie one on top of the other. They are prone to splitting up over the years, so don't be surprised if you find broken ones, or valves with no springs left at all (which would explain the lack of interstage safety valves). Bits end up in the interstage coolers, or even out at the check valve, which causes constant bleeding of the air from the tank when the compressor shuts off since the check valve cannot seat itself. You might be able to get away with taking the valves apart, cleaning up the discs, and lapping the valve faces flat. You can check to see if the valves are seating by dipping each valve into a parts cleaning vat and lifting them out. If the valves are ok, the holes in the valve bodies will hold the cleaning solvent with no leaks. If bad, the solvent will leak out in a matter of seconds. You can do this with both compressors.
Quality wise, it's a toss up. I see DeVilbiss 432's coming in for rebuilds that were installed in the 1950's. The bottom ends look factory fresh (you could reuse the bearing shells if you wanted to). DeVair dropped these machines because I think they are just not cost effective to build anymore (4 cylinder v-four 5hp with 8 valves?). They have the 247 pump for the 5-7.5 hp range (every bit as tough), which is a single block off their 10-15hp four cylinder 447 pump. Quincy, if anything, is a slightly higher quality pump, simply because it is pressure lubricated (DeVilbiss/DeVair claims the same, but it is a oil slinger ring affair, and pressure is produced through centrifugal force of the spinning crank). The valves are a bit better, the wristpins are pressure lubricated, the pump is protected from low oil pressure by the hydraulic unloader system, it is a bit quieter etc. I'd do a bit of investigating by pulling the inspection cover off of the 325 and maybe pulling the rod caps to see how the crank looks. Likewise, pulling off one block on the 432 might be worthwhile. If both pumps look good to rebuild, it might be ok to base your decision simply on how expensive it would be to rebuild either. Both are excellent designs.
JL Sargent
02-26-2005 20:26:38
 Re: Two Air Compressors Quincy 325 Devilbiss 432? in reply to Roger P., 02-26-2005 19:53:58
Ok great. Ill pull all valves tomorrow for inspection and parts washer test (cool idea). Maybe I can get by without the copper O-rings. I did replace the HP valve on a 308 4 or 5yrs ago and it still runs like a champ to this day (was just a broken spring). Anyway Ill post back what I find out. Id bet its the springs on most of em you see.
JL Sargent
02-28-2005 17:03:13
 Re: Two Air Compressors Quincy 325 Devilbiss 432? in reply to JL Sargent, 02-26-2005 20:26:38
325: On the unloading tower I did not see the O-ring or where to put it. My 325 is revision 14. Has one unloading tower on the LP side. Maybe its supposed to have two?
432: I called the few compressor shops here in Birmingham. AL and they sounded very uninterested in selling me parts for this pump. I did find complete valve kits online for this pump at a whopping $270.00. Needless to say Im disappointed in this.
Roger P.
02-28-2005 18:01:04
 Re: Two Air Compressors Quincy 325 Devilbiss 432? in reply to JL Sargent, 02-28-2005 17:03:13
One unloading tower simply means that it is setup for a stop/start operation. If you wanted a constant run machine, you would need an unloader on both the HP and LP cylinders, to prevent one from continuing to pump while the compressor is up to pressure. If there is one unloader, it should probably be on the HP intake valve, since it will blowdown all the pressure in the HP cylinder, the interstage tubing and the LP cylinder. The intake valves are one behind the other, on the side of the head that the intake filter is installed on. The HP intake valve is the one closest to the flywheel. Don't sweat the O-ring, it very rarely needs to be replaced, just anticipating trouble before it happens.
I am surprised that you would have trouble getting 432 parts. They are readily available from Independent Components Corporation (aftermarket parts) or from any DeVair dealer in your area. The ICC parts need to go through a compressor shop, since they don't sell directly to the public.
The only DeVair dealer I see in Alabama is a place called O'Reilly Auto parts, but it gives no location information. They are also listed as a sales office only.
JL Sargent
03-01-2005 13:29:40
 Re: Two Air Compressors Quincy 325 Devilbiss 432? in reply to Roger P., 02-28-2005 18:01:04
325: I have the compressor back together. This compressor has a 5hp motor 3phase. I have single phase here so Im building a Rotary Phase Converter for it. Ive built a few of these before. This will take me an evening or two to complete.
432: I found an O'reillys not far from me so Im going by there tomorrow. Maybe they can order parts for me. A valve kit for just one side of the pump will fix me up if I use some of the old springs. VRK-642 is the kit I found. I think I could make some springs but I also have 2 valve discs which are chipped. No way to lap that out.
Ill start a new thread at the top when Ive run the 325 with interstage pressures and any leaking (hopefully none!). Thanks so much for the help.
MBG
08-06-2005 10:02:56
 Re: Two Air Compressors Quincy 325 Devilbiss 432? in reply to JL Sargent, 03-01-2005 13:29:40
I have a DeVilbiss 432 S/N 58L61010 that was my fathers that I might be interested in selling. It run good but I am getting ready to move it from my late father"s shop to my house and am trying to get it overhauled before putting it at my place and I am having problems finding any one who will work on it and finding parts for it. If anyone is interested please respond to this email or if you know were to get parts and someone who will work (overhaul)on a DV 432 in the Huntsville Al area or southern middle TN area I would appreciate the advice. The mechanical market around here seems limited in ability with the only advice todate being don"t do any maintaince and to run it until it dies (which could be a while and is a waste of good equipment)and buy something new.
