Roger P.
02-25-2005 18:07:44
Re: Webster compressor in reply to Peter Brake, 02-25-2005 17:03:32
It's a Model 65 two stage compressor. Good up to 5 hp (real horsepower, not the fake 5hp like you see on the oilless units), which would get you around 17cfm. You can probably go as low as 2hp with it if you want. As tough as they come. Parts, if they are still available (which they should be) can be had from Compresseurs Quebec. Susceptible to small end wear, but they can be re-bushed to stock. They make good air, are quiet and last a long time. Check to see that the HP piston has not worn out in the pin bearing area, Websters were known for going out of round in the HP piston, as the cast iron they used was a bit "soft", especially if oil changes were neglected (ignored). If it has, you can bore it out and re-bush it with a nice bronze insert, as long as it isn't too far gone. In a pinch, you can turn down and polish a piece of 4130 shafting for a wrist pin, if none are available. Heat treated, it should be acceptable, although I have made them and left them as they were with good results. With a 5hp motor, I would shoot for around 750 - 900 rpm with a cutout of around 150psi, or less, depending on amp draw of the motor.
