Tool Talk Discussion Forum
7-12 mini lathe
bill b va
02-25-2005 15:24:14
about 3 years ago i bought this lathe new . so far i am well satisfied for the price . when i chuck a straight shaft in the 3 jaw chuck i get .001 run out (wobble) .i checked the shaft with a dial indicator . if i check the outer surface of the chuck it is true . this tells me the gripping surface of the jaws are not true . any suggestions how to true the jaws ..... ..thanks
Davis In SC
02-25-2005 17:22:48
 Re: 7-12 mini lathe in reply to bill b va, 02-25-2005 15:24:14
One thousandth TIR is almost no error for general shop work. Ony way to get any closer is a 4-jaw or Buck adjust-true 3 jaw chuck. Remember that indicator reading is double the true error... shaft is only one-half thou. off-center. I would say you got extremely lucky to have a 3-jaw chuck that runs so close.
Coloken
02-25-2005 16:58:22
Like Kraig says, .001 is pretty darn good for a 3 jaw. When you use a 3 jaw, the part you turn will be true but not to the end in the chuck. If you remove and re-chuck be sure to truth mark where you chuck it. For precision, setup using centers and a faceplate dog. I have the lathe too and am highly impressed with the quality for made in China. Would sell mine to a local though, since I no longer use it.
kraigWY
02-25-2005 15:36:53
Never trust a three jaw chuck, although 001 you can work with because the finish work will be outside the chuck. Fine a 4 jaw chuck and use the dial indicater to set up the work. Another option and one I like is get a set of collects to fit the head stock spendle whole. My 6x19 lathe uses #2 morse collets, I can also use these collets on my 12 X 36 lathe with step down collets. Anyway I wouldn't loose any sleep on the .001 runout on the jaw grips.
