Tool Talk Discussion Forum
Went to look at compressor today
Jay87T
02-25-2005 12:00:56
hey guys I went to check out this old compressor 60 gallon upright, the compressor head was HUGE cant see any stamps or markings on it looks like a 2 piston head one big one and one small one, the motor was a 1HP motor and this motor was a MONSTOR aswell, the guy fired up the compressor and took a really long time to fill up the tank can it be the motor does not spin fast enough? or thats how long these compressors took to fill up in 1951?
dr.sportster
02-26-2005 13:20:50
 Re: Went to look at compressor today in reply to Jay87T, 02-25-2005 12:00:56
I was going to shutup for once but I cant.{its like a disease].So anyway Ive had two big old free,real cheap price compressor stories.The free one needed a new head,then the guy from the factory that gave it to me said he wasnt authorized to give it away,It had to be loaded and returned.Then the cheap but ok old Devilbliss could not sandblast without "waiting periods" while pressure built up.Then I bought A Cambell =Hausfeild at home cheapo now Im ok to blast away.[Alot depends on usage,air requirement of your stuff but youll need a decent one]
Jay87T
02-26-2005 16:00:23
 Re: Went to look at compressor today in reply to dr.sportster, 02-26-2005 13:20:50
this is true but I just like that old 1951 style looking air compressor looking barnd new in my garage. one thing I find about this big moster is that its Quiet!
dr.sportster
02-27-2005 06:02:25
 Re: Went to look at compressor today in reply to Jay87T, 02-26-2005 16:00:23
Jay,One other thing [I know I always sound like Mr know it all but who cares]My little sears jobber has no belt/pulley guard this is totally unsafe and worse if kids are around.Make sure you use a belt guard for saftey.Know what you mean about the nice look of older stuff.
buickanddeere
02-25-2005 19:41:43
The shop this compressor came from maybe had a hydro service that would only run a 1HP motor? Of course my Grandfather would have taken a 3HP off and installed a 1HP. He figured it would only take 1/3 of the power onj the hydro bill to pump the tank full. Cast iron two stage pump or leave the thing sit. Is the bottom of the tank rotton?
thejdman01
02-25-2005 16:23:47
you have to consider it was fulling a 60 gal tank. i would agree that rings valves etc could make a huge difference. the great thing about most of those old monsters is they did have sleeves the problem woudl be finding parts or having them made. heat and speed will kill your air compressor. dont just speed it up to get more air. if the head is that big with that big of a tank and its factory somone didnt just stick a huge tank on it it is probably in need of repair. just like old motors,ship motors there real big but only run 190-200 rpm. that doesnt mean run them 1000 and get more power out of them. they arent made to run fast
LUCASSS
02-25-2005 13:10:22
ive seen some of those old compressors and they run slow and fill the tank slow.but back then they were used mostly for fillin tires. lucas
Jay87T
02-25-2005 13:28:45
 Re: Went to look at compressor today in reply to LUCASSS, 02-25-2005 13:10:22
Isnt it weird that such a huge pump I mean this thing must weight 200 lbs can be so inefficiant?
John K
02-28-2005 15:06:24
 Re: Went to look at compressor today in reply to Jay87T, 02-25-2005 13:28:45
Sit back and think, if you are comparing the fill rate to a 5 HP compressor, it stands to reason it will be 5 times slower. If the compressor is of early 50's vintage, it probably wasn't designed for high rpms and single phase motors were quite expansive for the bigger hp motors. For that motor to run the compressor, it needs a small pulley and a big pulley on the compressor thus the slow fill time. It fills slowly, and is quiet so what is the problem, are you running a production line or something? Remember that the old equip. if looked after will outlast any new stuff. Look at all the old tractors still working.
bill b va
02-25-2005 15:35:29
a little repair could make a lot of difference .condition of rings , valves and filter ? the filter could be chokeing the intake from not being changed in 20 years
humphrey
02-27-2005 03:15:49
 Re: Went to look at compressor today in reply to bill b va, 02-25-2005 15:35:29
Some of the earlier compressors had iron pistons and were slow running perhaps but would outlast anything produced these days. Sand blasting was unheard of then.
