Tool Talk Discussion Forum
Pull out drawers under workbench
Minn.Norske
02-23-2005 19:17:21
Anyone have any ideas or sketches for slides?
This is in my shop so they have to be built strong enough to hold heavy tools.E-mail me its not hidden! Thanks
Ken Crisman
02-24-2005 11:35:27
 Re: Pull out drawers under workbench in reply to Minn.Norske, 02-23-2005 19:17:21
The way they were built in the shop I worked at was very substantual . Held many air impacts , grinders , babbit hammers & more . After you build the drawers ; fasten a lenghth of angle on each drawer side . Now mount another lenghth of angle to the sides of the opening in bench so the drawer angle sits on it . Very strong setup .
Earl S.
02-24-2005 18:06:59
 Re: Pull out drawers under workbench in reply to Ken Crisman, 02-24-2005 11:35:27
Hi Ken,I thought my Dad invented that in the 50's. It sure did work nice. If it was a real heavy drawer we just put a dab of grease between the angles. Earl In Illinois
Chuck (VA)
02-24-2005 09:18:00
My plywood drawers ride on hardwood runners.
On top of the hardwood runners I glued 1-inch wide strips of high density plastic for the drawer bottom to ride on. This product is tuff. It is used on the bottom walls of freight trailers. Designed to take abuse from pallets, towmotor forks and freight rubbing against it. And it is only about 1/8 " thick. If you have a trailer repair shop they probably have scrap pieces you can have cheap. Works good for the amount of time I get to spend in the shop.
And the BIG pull out bins for wood/iron scraps etc. I bolted a set of $9 casters used for refrigerators to the bottom. They are good for 1000 lbs and pull straight.
steve_ne
02-24-2005 07:12:51
Cheap and strong
BALL BEARING DRAWER GUIDE
Rated load capacity of 175 lb. Two stage extension. see link below. I live in lincoln and can go check them out if you want me to. Have always kept them back in my head waiting for a project to come along.
Link
VaTom
02-24-2005 09:17:52
 Re: Pull out drawers under workbench in reply to steve_ne, 02-24-2005 07:12:51
Hi Steve,
Surplus Center's a great place and that's a great price. But it's a single piece undermount, and you notice they don't say who made it. Difficult to use, particularly in a shop situation. Even though it's a full extension, it's still extremely short.
Side mounts, where you buy a pair are much simpler as they only require sides for mounting, no carcase bottom under each drawer.
VaTom
02-24-2005 04:59:52
There are many companies offering heavy duty guides. But if you don't want to spend $15 (and up) per drawer, you have a couple of shop made choices.
I routed a slot into my 36" wide x 30" deep drawers. The drawers ride on hardboard runners attached to the carcase sides. These drawers are accessible from both sides so needed to open both ways. Been working well for the last 14 yrs.
You've gotta have some pretty sturdy drawers if you want large ones. I generally use oak or hickory sides, dovetailed, with a captured plywood bottom. If dovetailing sounds exotic, it isn't. A small router and a commercial dovetail jig make it almost foolproof. It was the first operation I taught new help in the cabinet shop.
If you're trying to get a full extension opening, without buying commercial guides, you're best off with sliding dovetails, one inside the other. Considerably more difficult to cut, but work well if you do it right.
Let me know if a picture would help.
ShepFL
02-24-2005 12:48:38
 Re: Pull out drawers under workbench in reply to VaTom, 02-24-2005 04:59:52
Ditto on the pic request. Will be building moveable workbench and this sounds like the cat's meow!
VaTom
02-24-2005 14:38:39
 Re: Pull out drawers under workbench in reply to ShepFL, 02-24-2005 12:48:38
Forum? Must be here someplace. I'll try.
farmweld
02-24-2005 12:13:41
could you post some pictures on the fourm? im sure others would like to try, if not use the idea you have. i know i would.
VaTom
02-24-2005 15:59:20
 Re: Pull out drawers under workbench in reply to farmweld, 02-24-2005 12:13:41
My apologies. I didn't know there was a place (Community Album) to post this type of photos here. Guess I should spend more time looking around.
Anyhow, there're pix of both sides of that crude bench. Then there're 2 pix of slightly more civilized drawers in the house here showing (or not [G]) different guides.
Hope Community Album was the proper place. Alternate Forums, whatever that is, isn't working.
Minn Norske
02-24-2005 05:21:22
To VA TOM Would you send some pictures! Thank you so much!!
VaTom
02-24-2005 08:58:27
 Re: Pull out drawers under workbench in reply to Minn Norske, 02-24-2005 05:21:22
Coming your way.
