Tool Talk Discussion Forum
Antique drill press chuck
Reido
02-23-2005 11:24:54
third party image
Hi Guys,
I acquired this drill press and would like too put it back in operation. It's the Post Style, and can be hand cranked, or Flat belted to a Line shaft. Has anybody ever seen this style Chuck? Or, somehow converted one to a Morse taper?
Thanks for any and all help.
Reido
Galen
02-23-2005 18:38:02
 Re: Antique drill press chuck in reply to Reido, 02-23-2005 11:24:54
Don't know the make of yours, but the two I have unscrewed from the shaft and I screwed on a Jacobs chuck from Harbor Freight ($5 2 years ago). Works great ever since.
Ed Weber
02-23-2005 17:08:14
Hi Reido This looks like the drill that I have. I believe the coupling with the bolt in its side,the piece above the skinner chuck is the actual chuck.If Im right, Seems to me We took the bolt out and heated the chuck with a torch to get it off. It was a tight press fit.The Shaft was hollow,and the end was cut flat. My machinist drilled and tapped it,and made a shaft adapter for a 1/2" jacobs chuck.It was a shaft threaded on both ends.We drew the new chuck up tight to the bottom of the shaft.That trued it up good. I use mine all the time. It works good. Make sure to oil your machine on a regular basis. Thats how I did mine. My drill Looks like yours but I cant say for sure. The imfo im giving you is from memory. I had this done many years ago. So procede with caution and good luck. Ed
Cliff (VA)
02-23-2005 17:02:07
My post drill has a collar that fits 1/2" round bits with a flat. Looks like the uppper half of the assembly on yours is the chuck. I don't know what the lower part is. I bow to someone who knows more than I.
Common modern 1/2" chucks are available with 1/2-20 threads. On my post drill I bought one of these and had a friend cut 1/2"-20 threads on a 1/2" steel bar. Presto, my post drill takes just about any drill bit less than 1/2".
Enjoy your drill.
Cliff (VA)
Roy Roach
03-21-2006 03:17:15
 Re: Antique drill press chuck in reply to Cliff (VA), 02-23-2005 17:02:07
Have a Canedy otto new #21 hand drill press in working order, new info on or buyer. Will drill as big as can be chucked up. excellent for big holes
Coloken
02-23-2005 14:53:16
 again in reply to Reido, 02-23-2005 11:24:54
I'm going to post again... Why do you want to change anything? that skinner chuck on it is probably better than anything you can buy today. Will take any size drill. If you can free it up. Looks like it is mounted in the spindel with a set screw. This is the usually for 1/2 inch round with a flat "black smith" drills. If the chuck is removable, sell it on E-bay,
sawtooth
02-23-2005 14:30:26
I have one similar I got at an auction for a buck or two, same kind of drill holding set up- need a set screw to hold the bit. You might be able to use a chuck with a straight shank with a flat on the shank. I don't attempt to use mine, it's just a decoration. Mine has top pieces missing/broken that once did a cam action and a dog that fed the drill down.
Reido
02-23-2005 13:13:12
 Re: Antique drill press chuck, another Pic in reply to Reido, 02-23-2005 11:24:54
third party image
Here is a shot of the whole thang.
Again, Thanks.
Reido
dr.sportster
02-23-2005 13:58:10
 Re: Antique drill press chuck, another Pic in reply to Reido, 02-23-2005 13:13:12
Few miles up the road a guys got one holding his mailbox.Looks like its from the machine shop display they have at the Smithsonian Museum.Nice.
Coloken
02-23-2005 12:28:20
 skinner chuck in reply to Reido, 02-23-2005 11:24:54
Thats called a skinner chuck. Not sure of spelling. I have one with Morse taper shaft. Use it in tailstock to hod drills. They grip very well. Chuck "might" come off if you can figure out how its held on.
Leroy
02-23-2005 12:19:06
I don't see a chuck there, looks like something stuck in place of a chuck, larger drils had 1/2" shank chuch for 1/2" diameter flat sidded bits that fastened in with a set screw, smaller had 3/8" but on bits of smaller diameter the shank that fastened into the drill was always the 3'8 or 1/2" diametor
