Tool Talk Discussion Forum
What makes a compressor motor
Bob in Ga
02-22-2005 20:08:49
I recently purchased a used compressor that has a 10hp 3phase motor. I am looking at changing to a smaller single phase motor, something like a 7.5 hp. What does it need? capacitor start, slower rpm 1750? magnetic starter?
Thanks
Bob
Coloken
02-23-2005 02:45:04
 Re: What makes a compressor motor in reply to Bob in Ga, 02-22-2005 20:08:49
What speed is the 3 phase motor? If it is by chance a 3500 rpm then you could use a 5 HP 1750 one. Other wise you would have to change pulley sizes if you run a smaller motor.
buickanddeere
02-22-2005 22:11:59
Compressor motors have a higher resistance rotor or even a double or triple bar rotor. The idea is to have a high resistance rotor for extra starting torque and another low resisitance set of rotor bars for higher running efficiency. The starting capacity maybe larger for a greta phase shift on single phase motor's start windings. A single phase motor will likly have a larger running capacitor to reduce line current as much a possible by getting the P.F. closer to unity.
Ol Chief
02-23-2005 04:40:32
 Re: What makes a compressor motor in reply to buickanddeere, 02-22-2005 22:11:59
I do not understand why anyone is operating a 10 HP compressor Without an unloader and time delay loading feature to allow no load starting.
old
02-22-2005 20:53:27
Well if its 10 hp 3 phase you will need to go with about the same size motor and or use a smaller pulley on the motor. When you get a motor buy what is called compressor duty type of motor.
