Tool Talk Discussion Forum
Cleaning aluminum
Jack B. Nimble
02-22-2005 11:20:22
Does anyone know a good home recipe for stripping oxidation from aluminum parts? I'm talking about a solution that parts could be dipped in that would remove oxidation and old anadizing without pitting the aluminum to prep them for polishing. Also wondering about the same thing for brass and copper.
Boog
03-03-2005 09:57:34
 Re: Cleaning aluminum in reply to Jack B. Nimble, 02-22-2005 11:20:22
Pasa-Jell 101
Alan Y.
02-23-2005 13:17:46
How about Duro Aluminum Jelly? It"s like Naval Jelly except it"s for aluminum not iron/steel.
J T L
02-22-2005 14:32:38
Contact me of list, and I can give you info on some metal cleaners that are not found in retail stores. I used them for some 20 years when I did sideline work for antique shops. They were not intended mainly for doing what you are asking, but they worked like a charm. My e-mail address is not blocked. John
Butcher
02-22-2005 18:06:23
 Re: Cleaning aluminum in reply to J T L, 02-22-2005 14:32:38
Yeah man, give it up. I want to know too.
dr.sportster
02-22-2005 16:48:56
Tell everybody.At least Id be curious.
Butch in NY
02-23-2005 13:20:28
 Re: Cleaning aluminum in reply to dr.sportster, 02-22-2005 16:48:56
Please post the list, I'd like to clean some bolt
on alum. parts on my truck Thank you
JoeK
02-23-2005 22:12:06
 Re: Cleaning aluminum in reply to Butch in NY, 02-23-2005 13:20:28
Always used"Simichrome" on motorcycle cases,also theres a "Flitz" aluminum cleaner/polish, and "Mothers"Aluminum Polish...For aluminum wheels and such most of the major auto wax companies make spray aluminum cleaners...CAUTION:AS SOME OF THESE SPRAY CLEANERS ARE FAIRLY NASTY ACID BASED COMPOUNDS,BE SURE IT IS MADE FOR ALUMINUM,AND FOLLOW DIRECTIONS CAREFULLY regarding usage,handling,masking overspray, rinsing/neutralizing.
dr.sportster
02-24-2005 03:02:54
 Re: Cleaning aluminum in reply to JoeK, 02-23-2005 22:12:06
Yes ,But I need something to remove clear anodizing from an already polished part.But apparently its a secret.Once you touch it to the buffing wheel your work is cut out for you.Tough to just "polish" away that stuff.Simichrome is my fave for touching up a polished part.
