jdemaris
02-21-2005 07:57:24
Crankcase sealing check in reply to MickPB, 02-20-2005 17:53:17
You need to take something into account when working on a two-stroke-cycle engine - especially chain saw engines like Homelites. Fuel delivery is dependent on the crankcase being sealed. If it's not, the rest of the fuel system won't work properly. Yes there are more obvious things to check i.e. & e.g. the fuel filter in the tank, the fuel filter in the carburetor, the fuel pump diaphragm, the vacuum port or the vacuum hose that hooks to the fuel pump in the carb, reed valve if it has one, etc. But . . . again - the engine depends on a sealed crankcase. I was a Homelite and Stihl mechanic for years (back to the 60s). If a saw had erratic fuel related problems, such as bad idling, hot starting issues, lean running, etc. - you first pulled the muffler and checked the exhaust port and cylinder liner in that area. That is usually the highest wear area - especially if the saw was running lean. If that looks okay, you then block the exhaust port, and also block the intake port - and then pressure test the crankcase. Very often the crankshaft seals leak - especially with Homelites because they are cheaply built and usually do not have ball bearings on both sides of the crank. In fact, some Homelites only have a needle bearing that rides directly on the crankshaft. We threw a lot of Homelite saws in the garbage due to worn out crankshafts. Not the problem with Stihl saws - at least not the older ones except for the little el-cheapo 015s. As far as just the crankshaft seals leaking, it is common for the seal on the sprocket side to get trashed and it's pretty easy to replace once the sprocket and clutch is off. So, if you have a persistent problem, you need to pressure check the crankcase. If it leaks, the air-fuel mixture will not be consistent no matter how much you fool around with the carburetor, hoses, gaskets, etc. Along the same line and being a little more general - two-stroke-cycle engines tend to use one of three common fuel-charge delivery designs. One is the roto-port which is rare - so I won't describe it. Another is the piston-port sealing design like Stihl uses, and another is the check-valve reed design like many Homelites use. When the piston is on its down stroke, it pressurizes the crankcase below the piston so the fuel charge can be delivered later to the combustion chamber above the piston. So, there must be a way of holding the charge, separating it from the combustion chamber, and then delivering it. Thus the three systems aforementioned. So, with a piston-port engine like most Stihls - if the piston or cylinder wall gets scored by the ports, fuel cannot be delivered properly. In a reed-checkvalve type engine like many Homelites - if the reed breaks, you get the same sort of fuel delivery problem. If your engine has a reed valve, it will be directly below the carburetor.
