Tool Talk Discussion Forum
Pole barn building question how to?
Loren
02-19-2005 17:34:10
Putting up the gable end siding(happens to be Suntuff in this example) and am trying to find out how to join the roof top flashing that corners over the top and the siding. Assume the siding hides up under the flashing but how far, and in what manner to fasten it and the flashing? I want to do it right for no problems in the future. This is rafters on one end and truss on the other. Thanks for any help you can afford. Loren.
ps. just thought I'll go a get a picture so it'll be more plain to see.
Keith-OR
02-21-2005 12:56:12
 Loren, Checked mine!!! in reply to Loren, 02-19-2005 17:34:10
Finually got a chance to get out to the other place to check mine, Flashing over the tin(top and sides), screwed on every rib on gable ends.
HTH...Keith in Gods country
Matt Smith
02-21-2005 06:57:53
 Re: Pole barn building question how to? in reply to Loren, 02-19-2005 17:34:10
On metal, we usually rivet the rake to the siding. I don't know if that SunTuff stuff will hold up to a rivet. You should call SunTuff to get their opinion.
Keith-OR
02-19-2005 20:12:53
Loren, my flashing went over the siding. it was the last thing put on. went over the roofing and siding. Our sheet metel was one piece, from edge of roof to ground. Put up end sheeting on then cut off at the angle of the trusses, after which put on the last sheet of roofing, then flashing.
HTH.... Keith in Gods country
PS. I am in eastern Oregon
Loren
02-19-2005 21:41:19
 Re: Pole barn building question how to? in reply to Keith-OR, 02-19-2005 20:12:53
Keith, did the screws on the top go throught the flashing AND the siding(I'd assume so)? I assume they also go through at the peak of the siding not the valley? With a backer under the siding? Thanks.
Keith-OR
02-19-2005 22:32:23
 Re: Pole barn building question how to? in reply to Loren, 02-19-2005 21:41:19
had no sub-siding, don't remember any scrws going through the flashing on the side of building. Will check in the morn and let you know. If I remember will get some pictures.
Keith
Loren
02-19-2005 17:50:40
 Pics in reply to Loren, 02-19-2005 17:34:10
Here's the Suntuff material.
[IMG]http://img.photobucket.com/albums/v341/lpctq/DSCF0136.jpg[/IMG]
The closeup of the flashing. [IMG]http://img.photobucket.com/albums/v341/lpctq/DSCF0134.jpg[/IMG]
And the overall.
[IMG]http://img.photobucket.com/albums/v341/lpctq/DSCF0135.jpg[/IMG]
Oh, and by the way, this is on Oregon if it matters. LOL
Loren
02-19-2005 17:54:15
 Hmmmm. in reply to Loren, 02-19-2005 17:50:40
third party image
Suntuff material
Loren
02-19-2005 17:57:49
 Re: Hmmmm. in reply to Loren, 02-19-2005 17:54:15
third party image
Closeup of flashing.
