Any experience with metal detectors?
Nathan(GA)
12-23-2000 19:25:29
I would like to purchase a metal detector for hunting treasures. Any suggestions on best buy for the money? I've been told "Whites" are good and went to their web site. They have so many to choose from. Kinda like buying a digital camera. Are the radio shack deals any good? Decisions, decisions?
Nathan(GA)
12-26-2000 08:22:05
 Re: Any experience with metal detectors? in reply to Nathan(GA), 12-23-2000 19:25:29
Thanks for the info folks. Unfortunately there are no places around here that rent the good ones or a variety. No gold prospecting except in North GA, 4 hours away. I'll find the KellyCo number. I did find out about a place about 2 hours from here that sells Whites among others and the guy is suppose to be real knowlegable about them. I'll ask about the Garrett. Hank, That sounds like an interesting project. However my electronics skills are limited to turning an item on or off. Again thanks for all the replies.
IHank
12-25-2000 19:49:52
Nathan- In the early 60's I built a beat frequency oscillator metal detector from diagrams and instructions in an electronics magazine. I did it more jest to see if I could do than anything. It was crude, but simple and inexpensive, plus it worked real good.
From memory now... I rolled a 1/2" copper tube into a hoop, leaving a gap. Opposite the gap was cut a hole to bring out the search coil wires and run 'em up the handle to the electronics box.
A five conductor phone hook up cable was snaked thru the tube. Wires on both ends of the cable were cut staggered about 2", soldered together while exposed in the gap in the tubing and the splices were insulated with tape.
Two wires were cut extra long and not spliced. The cable assembly was gradually snaked 1/2 turn inside the tube and the two long ends were pulled out. The hole in the tube and the gap was sealed with tape.
That created a five turn search coil, that radiated a magnetic field for ??? around it. The search coil was connected to an oscillator circuit in the electronics box.
Inside the box was a second oscillator circuit, that functioned as a reference frequency. The reference frequency was operator knob adjustable and tuned to operate real close to the search coil frequency.
A detector circuit operated between the search and reference oscillators. It put out a tone that represented the difference between the two oscillators and fed that signal to an earphone.
I'd fire the thing up and let it warm up and the two oscillators stabilize on frequency. Next I'd tune the thing to give a real low frequency (like 10 to 20 cycles per second) buzz.
Then head out and sweep the area to be searched.
A subtle thing I discovered... By tuning to give an audio signal in the 5 to 25 cps range I could tell the difference between ferros and non-ferros metal! Ferrous would make the audio buzz rate go the opposite direction from non-ferros stuff.
Example, if I came over a coin the buzz would slow down, go quiet, and possibly increase as the difference in the two oscillators crossed over. If I came over a pop bottle cap or nail, the buzz would speed up.
The buzz rate change was in proportion to the size and closeness of the object. I could read cast iron sewer pipe buried 6' under a lawn. Clay tile wouldn't give a signal. Copper gas line buried at 2' would give a distinct non-ferrous signal.
OK, so you asked the time of day and I described building a watch...
Have fun and find a pot of gold, or that tire eating cultivator shovel! Grins, IHank
Kermit
12-24-2000 17:57:53
Nathan, I've had several detectors. White makes a good detector, but I've been happiest with my Garrett GTA500. It uses a microprocessor to help with ground balance tuning. It's a turn on and hunt machine. It works very well, and I've found more with it than any other detector I've owned. Garrett has expanded their line of GTA detectors with several more models. Another coin hunter nearby uses a GTA1000 and is very happy with it also. I would recommend that you contact information for the toll free number of KellyCo in Winter Park, FL. They will send you a catalog and they sell all brands of detectors. They will offer advice and if you're unhappy with the dectector you buy they'll let you send it back and trade up for a better one. Their prices will be hard to beat. It would be worth your time to get their phone number. Sorry I don't have it at the moment.
ltf in nc
12-24-2000 12:15:34
The local pawn shop near me rents the White metal detectors for $5 /day. They have several models and it is a good way to evaluate the tool. Maybe you could find a rental source near yourself and try different models. Recently I used one of the rental units to locate the metal corner markers that had become overgrown and buried on a building lot that I am developing. Saved the expense of a suveyor as the county will not inspect the lot unless the corners are marked.
Fred OH
12-24-2000 04:48:16
My uncle Albert came in the shop one time and had lost one of the the snouts off of the end of the
corn picker. Wanted to know if I could make a new one. They are a twisty, spirally thing and I hated to have to make it. Probably take the better part of a day. Walked in the house and got out the metal detector for him. He was back in a couple of hours and said he found it, one of the wheels had run over it and buried it. The metal detector is a good tool to have around. You find all kind of uses for it. Today modern electronic advances make them all good and the new Whites Spectrum XLT is advertised as the best in the world. Supposedly tells you what's in the ground is on the screen. Sure come a long way from the old Relco, my first one. But expect to pay almost a grand for it. Research it out, get on the web and look. Theres a bunch of them on there. You don't have to go first class for the first one and they take in trades, so they have used ones too. Good family hobby and you never know when... L8R----Fred OH
T_Bone
12-23-2000 21:52:04
Hi Nathan, Take a trip to your local Gold prospecting shop and seek advice from them as they change so fast it's hard to keep up. There you can bury a hunted object outside, then see if the model your looking at will find it. Sure cuts down on the guess work on the ones that won't work!!!
T_Bone
RayP
12-23-2000 20:56:06
Daughter got me one of the cheap Radio Shacks when she was working for them. They are fair to poor. About all I use it for is finding spent pistol cases in the grass, which is about all it will spot. Anything burried is almost invisible to it.
Get a good one - if you're serious about the hobby - anything else and you'll be disappointed.
Merry Christmas!
