Small engine machine shops
Jeff
12-23-2000 18:15:39
I have a Kohler K181S that is in need of an oversize piston and possibly the crankshaft ground.
Can anyone advise me where there may be a shop that can to these machining operations, or, would it be less costly to order a shortblock?
Thanks
chuck
12-23-2000 18:37:22
 Re: Small engine machine shops in reply to Jeff, 12-23-2000 18:15:39
boring the cylinder can be accomplished with a rigid hone,most any automotive amchine shop can do that. the crank can be ground on any conventional crank grinding machine. kohler cranks can only be ground .010 undersize. depending on where you live, you might have to send the crank and block somewhere to have the job done, in any case you'll need to provide them with the new rod and piston at that time. might as well have the valves done also, it is still cheaper than a new engine. look in yellow pages for auto machine shop or ask at an auto parts store where a shop might be.
12-29-2000 13:09:39
 Re: Re: Small engine machine shops in reply to chuck, 12-23-2000 18:37:22
price wise i don,t think rebuilt is that much cheaper also with short block you probably get 90 day warrantycomplete new 2 years i had brigg and replaced in Sept mowed twice and then setnbut warramty kept on and ran out before i started in spring Would go with rebuilt if can time warranty
