Tool Talk Discussion Forum
rewire 1.5hp 3ph motor
kurtawickman
02-16-2005 16:42:27
Have an upright "60 250gal Worthington Comp. w/a dinasaour 1.5hp 3phs motor that needs hooking up to the breaker...However, tech plate for motor is nonexistant...(the glue is there but plate is not). Does any one know where one can obtain a schematic of this motor, so that I may keep the internal componants from "smoking", when I ultimatley do come to that point of having to "smoke test" my wiring? You my call Erny @ (408) 512-0215, or call me (Kurt) @ (408) 591-7325. Thanks Kurt @ Erny
Mike Burdick
02-16-2005 19:58:15
 Re: rewire 1.5hp 3ph motor in reply to kurtawickman, 02-16-2005 16:42:27
Kurt,
It is very doubtful that you'll find a schematic for the motor. I�d just remove it and take it to a motor repair shop and let them show you how to do it. Heck you don�t even know what voltage it is.
Since you said the motor is a �dinosaur� you might just consider getting another motor. Used small three phase motors like you have are very cheap � I imagine one like you need would go for less than $50.00. Check it out at the local motor shop.
Another option is to go to a scrap yard and see if they have one. Our local yard sells used three phase motors for $5.00/hp. If it doesn�t work they will take it back. Maybe you have something like that near you.
Good luck!
bigwood
02-16-2005 19:57:33
460v L1#1 L2#2 L3#3 tie#4&7 Together tie#5&8 Together and tie#6&9 Together. 208 &240v L1#1&7 L2#2&8 L3#3&9 Tie #4,5,6 Together This is a nine lead connection if you have a 12lead i will have to look up.
Jet9N
02-16-2005 17:04:24
Do the leads coming from the windings have tags on them? This would shed some light on the subject.
Jet
