Tool Talk Discussion Forum
Trig, not geometry
Kevin (Oh)
02-16-2005 10:46:13
52 degrees is real close and would probably work, given all errors in measuring, cutting, etc. Try 54.7 degrees.
Here is the logic I used:
A 2-1/2 " angle iron has 2.5" legs (when measured from the OUTSIDE) and an included 90 degree angle.
The distance, from the outside edges of the angel iron legs is 3.5355339" , (verify the distance of the hypotinuse by taking the square root of 2.5 squared plus 2.5 squared).
Knowing this, we can construct an equalateral triangle (look at his photograph and visualize looking a it from the back of the picture he has the template propped against). The left and right leg are each 2.5" long and the hypotinuse is 3.5.55339. The included angle is now NOT 90 degrees, but is apparently something else, since the iron is leaning into the plane. The solution is: Tan(x)= 3.53539/2.5 or about 54.7 degrees.
Let's see if some other more educated guys than me concur. Statistics, not trig, is my strong suit. Could be wrong.
Vern-MI
02-19-2005 06:10:53
 Re: Trig, not geometry in reply to Kevin (Oh), 02-16-2005 10:46:13
Kevin has the right answer. The angle that Puttz has identified in his sketch should be the compliment of 54.7 degrees or in other words 35-1/4 degree. That works when the angle is laid on its side and up against the fence of the cutting saw. That will work for any length of angle by the way. the difference is that if the angle is short enough there will not be an openning under it.
