Tool Talk Discussion Forum
right tool to shave drywall
diggerdave
02-15-2005 13:00:59
Hi wondering what the best tool or way to trim dry wall overhang is. Here is the situation: New addition, so everything is new. Anyway on several window openings the drywall is not flush with the actual Anderson window (wood frame). Its only off by a bit but enough that if I were to put the trim it would not lay flat. This is not a case of wavy drywall. (hope that makes sense..)I have been told that all you need to do is �shave� the drywall. Question is what do I shave it with and what is best way since I really don�t want to cut into the wood casing of the window by accident� thanks in advance
Don L C
02-17-2005 19:26:37
 Re: right tool to shave drywall in reply to diggerdave, 02-15-2005 13:00:59
Shave the edge with a box knife...drag the knife sideways across the raw edge .....
Dug
02-17-2005 16:43:32
Use a sharp razor knife and score deep along the trim edge where the drywall is too long. Continue to score, deeper and deeper with each pass until you cut all the way through.
Dug
Bud in NC
02-16-2005 04:27:11
Back when I worked as a carpenter, etc we"d just use an old hand saw. Use the 2x4 as a guide for the side of blade and in a few strokes it was done. Old hand saws are cheap, too.
Rod in Smiths Falls, ON,
02-15-2005 20:30:49
You mentioned that you have a number of windows where fitting the trim is posing a problem. For one window I would go with the frenzy with the hammer, but if there are more, I'd work with the wood.
If you have a jointer, just taper enough out of the piece of window trim to fit the space. Set the cut very fine, remove the guard, and begin the cut where you want to start the taper, carrying on to the end of the piece. Do this a couple of times carefully and you'll have exactly the tapered fit you want. Use a push stick, for you will need your fingers to hold the nails later.
If you need the inside edge of the casing to remain on the same plane as the rest of the trim, set your fence so that you cut a rabbet on the trim, leaving the inside edge alone.
Mike Burdick
02-15-2005 17:48:05
diggerdave,
Here's another discussion on another forum concerning your question that may be helpful.
You also might find more ideas by doing a Google search.
Dale in WV
02-15-2005 15:31:59
I like the idea of shimming out the frame to the proper depth -- making it level with surrounding walls. To me, Midwest Redneck has the right idea.
I agree..John,PA
02-15-2005 17:15:48
 Re: right tool to shave drywall in reply to Dale in WV, 02-15-2005 15:31:59
I agree on shimming the door framing when working with wavy walls. John,PA
Midwest redneck
02-15-2005 14:33:26
If it were me.... I am much better at woodwork then drywall and tile. Here is what I would do, I understand what you are saying lets say that the drywall is 1/4 higher next to the casing. Buy some wood trim that fits perfectly over the casing (like bead trim) and this bead trim would be higher then the drywall then to finish off the edge where the drywall meets the casing use caulk of what ever color.
ShepFL
02-15-2005 14:18:02
When building my new home I went out and bought a Rotozip. Handiest tool I found for drywall work. Used it to cut outlets, speaker holes etc. etc. etc.
Not been used much after house is done but still handy tool to have around. Never can have to many tools :)
mud
02-15-2005 14:16:43
I spent nearly 3 decades trimming out houses. Here is what I have found that works:
1. If you can get a knife blade on the backside of the rock, then score it. Then pull it toward you and score it on the outside. It'll break off along those scores.
2. Stanley Sureform rasp does a neat job.
3, Drywall saw
Frank (N.Mi.)
02-15-2005 14:08:09
Dave, is the drywall sticking farther out then the wood jambs of the windows? If that is the case then you position pieces of the trim exactly where it would go when nailed on. Tack them in place as a guide. Pencil a line on the outside edge. Do this all the way around the window. Remove tacked on guide trim piece. If the drywall is only 1/8" high just take your hammer and tap repeatedly on the drywall STAYING INSIDE THE LINES. Do this till the trim lies flat. If the drywall is more then 1/8" high, cut the paper face of the drywall 1/16" inside the lines, tap as above and remove the paper face. With sandpaper or hammer taps adjust to fit....Frank
ChrisH(IA)
02-16-2005 06:26:42
 Re: right tool to shave drywall in reply to Frank (N.Mi.), 02-15-2005 14:08:09
Hello, Diggerdave. Frank's way is the best--I've been a trim carpenter nearly 40 years and as an apprentice I was shown how to do it that way. Also take a foot long piece of scrap trim and miter both ends at a 45 degree angle to test fit your corners. You can then "adjust" your miter saw so each piece fits WITHOUT a gap you can throw a cat thru. (putty is for nail holes) ChrisH (IA)
Hound
02-15-2005 13:19:37
...btw...don't use your chainsaw -don't ask.
Vern-MI
02-15-2005 13:15:18
Drywall rasp or a RotoZip with special guide tip.
