Compressed air
Bus Driver
12-23-2000 07:02:13
Considering the current interest in air compressors, there is another safety warning to consider. Some years ago, I got the bright idea to use PVC pipe for air. It had the pressure ratings, will not rust, low cost, quick to install, all those good things. Fortunately, I asked some questions first. PVC is weakened by oils such as compressor oil. Further, PVC gets more brittle with age and when it is cold. A piece of PVC ten feet long with 125 PSI air in it is the world's longest hand grenade! The CABO building code for houses no longer permits PVC for pressure piping, only for drain, waste and vent (DWV)for which it is fine. There is a company making non-metallic air piping. I chucked their literature when I learned that the piping is at least ten times the cost of other plastics, The joints are made with special heat welding equipment which is also costly. I could continue, but to get to the bottom line, DO NOT USE ANY PLASTIC PIPING FOR COMPRESSED AIR UNLESS THE MANUFACTURER RECOMMENDS IT. Sorry for raising my voice. It would hurt me if you got hurt.
ltf in nc
12-24-2000 12:34:09
 Re: Compressed air in reply to Bus Driver, 12-23-2000 07:02:13
How correct you are! I worked for a major compressor manufacturer and their policy was that if a service person visited a facility that used PVC for air delivery no work was to be done and the employee was to return to the plant after acknowleging to management as to why the equipment was not being serviced. I have also seen the bowls on inline oilers and filters burst after their reacting with synthetic oil.
clay
12-24-2000 10:23:20
thank you for the information on useing plastic pcv pipe for air lines
I thought I would put it in my garage but now i'll will wait and put metal pipes in it's not worth getting hurt over. thank u again
luckydog
12-23-2000 09:20:28
Thanks Bus Driver-- Was thinking of doing the same until I just read your post!! Have a very Merry Christmas!! luckydog
Bus Driver
12-24-2000 11:27:11
 Re: Re: Compressed air in reply to luckydog, 12-23-2000 09:20:28
What joy to know that I might have done some good. If you want a glimpse of my good fortune, see my post on the JD board. While you savor your good health, you might click on this link.
