Tool Talk Discussion Forum
Mapp Gas Torch
Gregg
02-14-2005 20:47:40
Has anyone had any experience with the bernzomatic Mapp gas / Oxygen torch. You are suppost to be able to cut bolts and braze with. I only have small jobs in mind and maybe heating the odd stubborn bolt. The tanks on these are the same as your small plumbing propane tanks. A friend has a large oxy/actylene for any larger jobs.
Kendall
02-17-2005 06:53:10
 Re: Mapp Gas Torch in reply to Gregg, 02-14-2005 20:47:40
If you ONLY have a very small job, it will work.(jewelery) The Ox tank only last 7 or 10 minutes and cost too much. I have one and found it to be a waste of money. Dont count on cutting anything. I went through a few Ox bottles on a project and swore off if it after that and bought real Ox/Ac tanks for the torch I already had. The money I spent on oxygen on that project could have gone into those shorty tanks. If you want to heat and braze and dont want to buy ox/ac torch setup, you'd be better off buying an air/acetylene torch like plumbers use. Whatever you do, keep in mind the money you spend on the Mapp/Ox torch will be beter spent on a real torch and you'll be happier with it.
Dick L
02-15-2005 13:18:12
I have used mapp for close to 45 years for cutting and some brazing. I set the map a 5 pounds and never set the oxygen above 20 pounds. Anything over a 20 pound setting on the oxygen just blows the oxygen away. I have no problem cutting 1/2 plate at this setting. I have never noticed extra oxygen use with mapp over acetylene, but it sure takes a lot less mapp for the same amount of cutting. Almost every time a new man uses this setup that has used a acetylene rig before I can explain this, they cranks up the oxygen pressure. Then I get to order up an fresh tank of oxygen.
Georgia Boy
02-15-2005 11:02:55
I bought one recently to help get off stubborn, rusted bolts. The problem is I use up an entire tank of oxygen just getting one bolt heated up, and that gets expensive. I'm going to get one of the Genreco carry-around oxy-acetylene outfits.
Vern-MI
02-15-2005 02:24:30
T_Bone
02-15-2005 03:20:08
 Re: Mapp Gas Torch in reply to Vern-MI, 02-15-2005 02:24:30
Hi Gregg,
Don't confuse Oxy/Gas combinations with a Air/Gas mix. Pure Oxygen greatly increases flame tempature.
Example: Propane/Air = 2825�F
Acet/Oxy= 5900�F
Propane/Oxy= 4580�F
Propaylene/Oxy= 5900�F
Mapp/Oxy=5300�F
I've used Mapp/Air with my Benzomatic torch that works well for some applications but not welding.
T_Bone
Davis In SC
02-14-2005 21:07:35
Bought one as a teen..... almost 30 years ago. I had all kind of projects planned to do with it, until I discovered that that 5 dollar oxygen bottle only lasted several minutes. At that time, I was working all weekend for less than twenty dollars. Losing proposition..... ...
Big Jim
02-14-2005 23:11:55
 Re: Mapp Gas Torch in reply to Davis In SC, 02-14-2005 21:07:35
That is exactly the comment I've heard about them from lots of people. You'll spend a whole bunch for the oxygen bottles and they always run out right in the middle of the project.
J puleo
02-16-2005 08:13:02
 Re: Mapp Gas Torch in reply to Big Jim, 02-14-2005 23:11:55
Ive got one, there OK but burn out small o2 tanks quickly as the other posters stated. Id be happy to sent it to you for $15 if you want it. I never use it.
