Tool Talk Discussion Forum
Slow learner
Bill57
02-14-2005 20:39:02
I've developed an appreciation for McCormick Farmall nuts and bolts after I foolishly took a hard chisel to a stuck nut on my sickle mower for my SA. (See previous post to observe a rookie in action.) Live and learn. That nut was a beauty. Where do I get good grade nuts and bolts, or better, original nuts and bolts for a Super A? Not only do I need one for the mower, but I also need a few bolts for the drawbar area under the rear axle. The big, long ones at the rear and the next set of smaller bolts (pins?) farther forward.
Until I tried ones from the local Ace Hardware, I didn't know how well machined and solid the originals were. My Binder operator's manual doesn't seem to specify them. Thought I'd ask here before calling around.
Thanks a lot,
Bill in Alabama
Bill WI
02-15-2005 08:13:09
 Re: Slow learner in reply to Bill57, 02-14-2005 20:39:02
Looking at the posts, you'll need to specify heavy nuts. If you have a machine shop or old hardware store or do you have a Fastenal bolt shop around that supplies the shops? I see at Mc Master you'd have to buy 50. I think those axle nuts are what they call T-slot nuts. They're used for fixtureing or clamping on machines.
Bill57
02-15-2005 08:32:07
 Re: Slow learner in reply to Bill WI , 02-15-2005 08:13:09
The ones I do have are hex heads, not T's, but maybe T's would work. And, yep, I'm trying to clamp my sickle bar mower on with them. I have a Fastenal over in Selma, so I'll check with them. Thanks for the suggestion; I sure don't need 50 of them!
Bill
Bill WI
02-15-2005 21:11:31
 Re: Slow learner in reply to Bill57, 02-15-2005 08:32:07
What I was refering to as T's were in the McMaster catalog under T nuts but not the T's that fit in the grooves. As I see it they used them on the other side of the stud. I had the McCormic H's and know your talking about them heavy nuts that are about double in length. Wonder if a coupling nut could be faced off. there must be some good used ones out there though.
MLP
02-15-2005 05:23:11
McMaster-Carr has a wide selection of bolts from grade two to better than grade eight. They have them in different types and coatings. I like the Ultra coat they are expensive but they are the best bolt that I have found so far. In the top left hand corner type Armor coated bolts.
Bill57
02-15-2005 05:54:28
 Re: Slow learner in reply to MLP, 02-15-2005 05:23:11
MLP - that's an awesome site, so detailed. Thanks much.
Bill
dr.sportster
02-15-2005 05:15:07
I dont think they make hardware like they used to.You may have to find dealers that still have originals in stock.That or dig through the milk crates at auctions and swap meets.
Bill57
02-15-2005 05:57:13
 Re: Slow learner in reply to dr.sportster, 02-15-2005 05:15:07
I'd have to agree with you. Never worked with heavy metal before, but I now realize it's hard to find stuff that will stand up to the pounding and pressure. Thanks for replying. I'm keeping my eyes peeled.
Bill
Charles Park
02-15-2005 04:18:22
You might try OEM Tractor Parts. They have a web site.
Bill57
02-15-2005 06:10:44
 Re: Slow learner in reply to Charles Park, 02-15-2005 04:18:22
Thanks for the reply, I'm in touch with them. Mike seems like a helpful sort.
Bill
