Tool Talk Discussion Forum
Second thoughts
Coloken
02-14-2005 07:16:30
Kind of wish I hadn't written that...too early in the morning. Wish I could pull it. More I think about it... If that long rod can be removed, its a bolt. If it stays in place, its a stud. Would that be right? Like a head bolt or a exhaust manifold stud?
Fawteen
02-14-2005 15:28:10
 Re: Second thoughts in reply to Coloken, 02-14-2005 07:16:30
There ya go. A stud may be pressed in or threaded in, but is not intended to be removed in the normal course of things. Also, studs don't have hex heads.
I got to thinking on the way to work after I posted that this morning that I'd screwed up, cuz the wheels on my Jap Deere CUT have threaded holes in the axle flange and use taper-headed bolts to hold the wheel on. It struck me as possible that he had the same situation and had broken a couple of bolts with the threaded portion still in the axle flange. He'd have been in DEEP doo-doo if he'd followed my advice under those circumstances.
Reading his reply, I see that I lucked out and he does actually have pressed-in studs. Whew...
caseyc
02-14-2005 08:22:53
i agree the second time around. i work in the auto industry so a stud would be pressed into the hub and would accept a lug nut. a "bolt" would act like a lug nut only screws into the hub to hold the wheel on. just my 2 cents.
casey in SD
Mike M
02-14-2005 08:06:04
Kinda like everyone calling an engine a motor ?
greenbeanman in Kansas
02-14-2005 08:58:57
 Re: Second thoughts in reply to Mike M, 02-14-2005 08:06:04
Hey, I resent that, then again I'm not everyone.
I make it a point to distinguish between a motor and an engine. Motors are electric, engines are internal or external combustion. External you say? Yes, like a steam engine.
I deem the second example correct for stud vs. bolt.
Frank M.
02-14-2005 19:21:12
 Re: Second thoughts in reply to greenbeanman in Kansas, 02-14-2005 08:58:57
I've heard the engine vs motor debate several times. My opinion is the terms are almost interchangeable.
Remember, the next time you're riding your enginecycle, watch out for all the rest of the engineists on the road.
Frank M.
wdtom
02-14-2005 18:31:44
Motors can also be air, or hydraulic, point being a motor gets it's energy form far away, and engine makes it right there, no wires, or pipes bringing it in from who knows how far away.
02-14-2005 20:14:40
 100% correct in reply to wdtom, 02-14-2005 18:31:44
You are certainly correct, I just wasn't thinking of the others when I made the post.
Coloken
02-14-2005 10:58:18
 hit or miss in reply to greenbeanman in Kansas, 02-14-2005 08:58:57
Dare I bring up that every body with and old gasoline (not gas)horizontal engine calls it a "hit or miss" even when it has a carburator type governor?
