Hi All,Great forum, I"ve learnt a lot even if it is really difficult to work through threads in plain text indented down pages instead of conecutive html formatted posts on self-contained topics - hopefully that"ll change when I become a member. Speaking of which, how does one sign up? I"ve spent an hour looking but can"t see a "new member" or "create login" link anywhere. I have acquired an old, but in working condition TA20 (which from reading here I think is a TAE 20) grey MF petrol tractor with a 5 acre property recently Down Under. The previous owner didn"t do much maintenance, including wheel nut tightening, and I didn"t know to look / check them (I naively assumed they were like car wheel nuts) with the result 5 of the 8 wheel nuts worked loose over time and those studs have sheared off. I am trying to remove those sheared studs but don"t have much skill or equipment. Other posts talk about welding a nut on but although that might help for removing bolts where the head has twisted off, it won"t for studs (that I can see) and I don"t have welding equipment or skill anyway. Another thread mentioned heating the stud and tapping out, which I have tried (5 minutes with a butane torch) but to no avail. Another theme is drilling out with left-hand thread bits but this seems to be more for bolts with threads than the studs which are designed to tap out through the stud holes (the thread is just for the retaining nuts). The only thing left to me that I can pickup from this forum is simply drilling it out. I assume I need to use a special hardened drill bit (which I"ll need to buy)? Or possibly 2 - one for a pilot hole and the other just smaller than the stud hole in the disc? Is that correct? Anything else I can try for studs? Thanks in advance - Dave aka Apprentice_GM
