Tool Talk Discussion Forum
Ultrasonic Cleaners
rustywheel
02-12-2005 18:12:52
Has anyone used an Ultrasonic Cleaner for cleaning Carburetors, and other small parts. how good do they work and what type of cleaning solution do you use.
JT
02-13-2005 15:05:21
 Re: Ultrasonic Cleaners in reply to rustywheel, 02-12-2005 18:12:52
If you buy a decent one, they work great, these little $20.00 ones you see on ebay are not worth taking home. Brnason is probably one of the better ones.
T_Bone
02-13-2005 07:50:30
Hi rusty,
I've used them for cleaning gold and antique clock movements and they work very well. Depends on what your cleaning determines the chemical.
All the units I've seen has been a SS tank, so no worry about most chemicals.
Ammonia works well on alot of things. Gold brass, silver.
Dawn dishwashing liquid works well on grease.
There's nothing that beats Berryman B12 carb cleaner, any auto supply. Use outside as enclosed with sparks would be darn right explosive.
T_Bone
Davis In SC
02-12-2005 19:28:52
Never tried it on Carbs, but I Use a Branson U/S unit at the shop to clean small components for plastic injection molds. I just use an Alkiline cleaner, such as Purple Power to 3 parts water. It works well, you can see the dirt wash away as it runs. However, for Carbs, I think the key is soaking in a solvent that will dissolve varnish, it has to be petro based, rather than water-based. My U/S cleaner is heated , up to 160F,& it has a warning against using flammable solvents.
