Tool Talk Discussion Forum
Homelite Super 7 Spring reload
Kaenath
02-12-2005 14:58:27
I broke the string on my super 7 today. Pulled off the cover, pulled off the wheel, and accidentally pulled out the retraction spring. The machine runs like a dream, and I would hate to stop using it. Does anyone have instructions on how to reload it? There is three peices of spring steel involved: one still in the housing, the main spring, and a shorter piece of steel with a hole in one end.
JT
02-13-2005 14:58:01
 Re: Homelite Super 7 Spring reload in reply to Kaenath, 02-12-2005 14:58:27
If you have a Super 2 and have 3 peices of spring, then you need to replace it. anyone who carries small engine parts can get you a new spring through aftermarket companies. This is a very common saw.
Vintage Homelite
02-12-2005 22:29:00
We've been a HOMELITE dealer for over 50 years & never heard of a Super 7... Can you describe it further? Does it have a UT#?
Send me your phone# & I will call if you are in the U.S.
Bill
Vintage Homelite
02-13-2005 19:01:04
 Re: Homelite Super 2 Spring reload in reply to Vintage Homelite, 02-12-2005 22:29:00
JT is correct...Yours is broken. If your case is plastic the spring should be inclosed in a tin container with the open side to the outside. If plastic, the open spring will have a 'hook' to catch a notch in the case. I stock both. Contact me if you still need one.
Thanks
Bill
Kaenath
02-12-2005 23:03:52
 Re: Homelite Super 7 Spring reload in reply to Vintage Homelite, 02-12-2005 22:29:00
Sorry, Super 2 Homelite, not 7
Kaenath
02-12-2005 23:03:23
Sorry, Super Homelite, not 7
