Tool Talk Discussion Forum
Vickers Pump for Splitter
Redd
02-12-2005 10:08:00
I have a wood splitter which was given to me. Its minus engine and hyd pump. I have a good 5hp engine and I got a Vickers pump from an electric forklift. Its the right rotation and has a flat tang drive which shouldn't be a problem but can someone identify the specs i.e. gpm etc from the numbers on it? I was told by a guy that builds a lot of splitters if you use a large single stage pump insread of a smaller two stage the cyl flies out too fast until it hits the wood instead of a smooth stroke.
Paul Janke
02-13-2005 06:53:06
 Re: Vickers Pump for Splitter in reply to Redd, 02-12-2005 10:08:00
I run my splitter with the pump on my tractor. One less engine to maintain, one more use for the tractor.
NC Wayne
02-12-2005 19:09:14
Hey Redd, the guy you talked to didn't actually explain things to you right. The pump being a single or two stage pump isn't gonna effect how smooth the cylinder comes out, only the amount of HP your gonna need to reach the pressure you want. Also it doesn't matter wether a pump is one stage or two so far as the speed goes, at least not til the ram actually hits the wood. If you have a single stage pump that puts out say 5 GPM at 3600 RPM you can also have a two stage pump that puts out 5 GPM at 3600 RPM meaning the cylinder is gonna come out at the same speed no matter what kind of pump your using. The difference comes in because basically the single stage pump is gonna put out 5GPM throughout it's pressure range wether it's doing it at 200psi or 2000 psi as long as the RPMs remain constant. This means as the pressure rises you need more and more HP to turn the pump because the volume is staying the same. In order to do this you need a large engine with enough HP enough to turn the pump at max flow and pressure. The two stage pump is also gonna be putting out 5 GPM at 3600 RPM, but only til it reaches a set pressure. When the set pressure is reached an internal valve shifts and the second stage takes over putting out say 1 GPM at 2000psi. This allows you to use a smaller HP engine and still have a high enough flow for the ram to come out quick, then when it hits the wood and builds to the set pressure it shifts to low gear to give you the higher pressure needed to actually split the wood but at a lower volume. Short and sweet, a two stage pump gives you the ability to use a smaller engine while still maintaining a faster cycle time on the cylinder and still having enough pressure available when needed to split the tough stuff than you'd be able to do with a single stage pump.
kidbob
02-12-2005 13:43:08
The formula from the fluid power manual is:
GPM X PSI / (1714 X .85) = HP Electric
GPM X PSI / (1714 X .85) X 2 = HP Gas
Midwest redneck
02-12-2005 12:02:39
You need a double pump for splitters. In short you need to be able to advance the cylinder quickly until the ram hits the log then it slows down and pressurizes to higher value. Look in the grainger book and select one. The formula to find out HP needed for pumps is GPM X PSI / 1750 (I think)
Paul Janke
02-13-2005 06:48:43
 Re: Vickers Pump for Splitter in reply to Midwest redneck, 02-12-2005 12:02:39
You are very close. GPM times PSI divided by 1714 equals HP.
