Tool Talk Discussion Forum
sears generator doesn't work
oliverdave
02-11-2005 18:00:14
I have a sears generator that the generator part isn't working. The person I got it from said that it would work a little and then turn off,but when I got it and started it, it didn't do any thing. Some one took two wires from the the generator before the regulator and put a splice in both of them and brought them out to a splice block. Why would they do that and why is it not working?
oliverdave
02-12-2005 14:30:43
 Re: sears generator doesn't work in reply to oliverdave, 02-11-2005 18:00:14
I went out to flash it ,when I started it and pluged the drill in,it worked ,then when I shut it off and started it again it wouldn't generat, I tryed to flash it with a drill but it didn't work ,what could be going on?
HarryG
02-12-2005 09:07:45
Here is a link that details how to easily "Flash" the field. I've done it and know it works.
Link
Regards, HarryG
Joe (Wa)
02-11-2005 21:43:11
Here is a link.
Charles (in GA)
02-11-2005 19:37:42
As has been noted on this board recently, an easy way to flash a 120V AC generator is to start it up, plug in a cord type drill that has a motor with brushes, and turn it on. If it doesn't run, rotate the drill by hand (backward I recall, but not sure) and that will "flash" the generator.
Someone recently did note that they tried it on a generator with no output and it worked.
Charles
buickanddeere
02-11-2005 19:16:41
So they have a place to energize the field with a battery to "flash" it.
oliverdave
02-12-2005 06:38:33
 Re: sears generator doesn't work in reply to buickanddeere, 02-11-2005 19:16:41
Thanks everyone.I wondered if that was what it was all about.I know car alt need it but I didn't think this needed it. So I should be able to put a 9volt to those wires and it will work,but i'll try the drill first.
