Tool Talk Discussion Forum
Thanks for your help with sandblaster!
Charles Park
02-11-2005 06:04:42
Never thought I would get so excited about sand coming out the end of a hose. Finally got my Harbor Freight blaster to work. Thanks to you guys that answered my questions as those posed by Tweeter recently.
Carol Martin, in particular you were very helpful. It works!!!! Hope I can help you guys someday. Always seems like there are some really nice people at antiquetractors.com.
jmoore
02-11-2005 13:48:31
 Re: Thanks for your help with sandblaster! in reply to Charles Park, 02-11-2005 06:04:42
Alays nice to hear a report back as to how things worked out.
Carol Martin
02-11-2005 09:34:39
Hi: I have had a problem with My HF sandblaster that once in a while. The lower valve will get clogged with moist sand (like mud) not sure why the sand is not damp at all and filters are empty on the compressor.. Was a real pain to take the hose off and clean out that valve.. so On the bottom manifold assy I Drilled a hole down thru where it screws onto the valve and threaded it to take a 5/16 bolt and just made a little 5/16 plug to put in it.. Now all I have to do is remove the plug and run a 1/4 drill bit up into the valve by hand to clean it out saves a lot of aggrivation..
Carol
dr.sportster
02-11-2005 11:42:35
 Re: Thanks for your help with sandblaster! in reply to Carol Martin, 02-11-2005 09:34:39
Hey Carol,Once a pipe broke and squirted mine full of water when it was half full of sand.Talk about a moisture cleanout.Charles good luck with yours.
Charles Pak
02-11-2005 11:10:52
Carol, you were a real help with this. Mine is working just right thanks to you! The sequence of turning on the valves did the trick! Thanks.
