Tool Talk Discussion Forum
Jet Tools
No reserved nam
02-11-2005 05:09:37
Anyone have these?,been seeing alot of these in all the differant tool stores.
Been looking at the table saws and sanders.
Thanks
dr.sportster
02-12-2005 05:57:49
 Re: Jet Tools in reply to No reserved name, 02-11-2005 05:09:37
My 1888 Van Norman horizontal mill got into a bar fight last night with three Jet milling machines off some foriegn ship that was in port.The Van norman had some cutting oil spilled down the front but they took the three Jet mills away in the scrap metal ambulance.
Rod in Smiths Falls, ON,
02-11-2005 15:43:10
An article in Fine Woodworking about five years ago looked at the factory in Taiwan where 15" planers are made for all the companies who sell one (except Makita). Yes, they are all thrown from the same moulds at the casting stage, but the best of the castings and more refined parts go to the higher-end machines from companies such as Delta, Powermatic and General(International). I don't know about Jet or Grizzly, as the Canadian equivalents are known as King and Craftex.
The issue also showed the manufacture of band saws, in particular the effort or lack of it put into getting proper balance and allignment as the machines are assembled.
I have a 1976 Delta 14" band saw and it is noisy and rough running, but a very serviceable machine. I recently bought a 1988 King 14" because it ran so smoothly when I turned it on. Turns out the castings are so flexible I can't keep blade tension on it, and the things which should be finger tightened require a wrench, and vice versa. Before long I managed to break the blade holder and the whole thing is now scrap until I find a replacement. It's a terrible machine.
My 15" Taiwanese General International planer, on the other hand, has worked for ten years without a complaint.
The Fine Woodworking article concluded that the designs of the larger tools were fine. Quality control and secondary parts are the big issues.
02-11-2005 19:23:02
 Re: Jet Tools in reply to Rod in Smiths Falls, ON, , 02-11-2005 15:43:10
If you are looking at a new unit something to check is the amount of travel of each of the adjustments. I ran into an 8" Craftex jointer in my school shop which had no travel on the outfeed table because the castings hadn't been cleaned properly at the factory.
big fred
02-11-2005 10:05:56
I have the Jet contractor"s table saw and am very happy with it. It"s not up to the level of my friends Powermatic 66 cabinetmakers saw, but it"s better than the Delta contractor saw.
Kraig WY
02-11-2005 09:01:35
I have a two jet lathes, and a milling machine, they have been going strong for over 20 years now, Taiwan or not they have been working for me.
I also have one of their bench sanders and metal ban saw. If you have their web site I would like to get a manuel for my milling machine, the speed change (belts) list I have is to faded for my old eyes/
No reserved name
02-11-2005 08:33:25
Thanks for the replys.
I just want one for home use but want and will pay for a good one.
I bought the craftsman contractors model years ago and will be throwing it out,tired of trying to keep it running.
Jack B. Nimble
02-11-2005 07:47:13
I buy the equipment for a large construction co. and we have several older Jet tools and have had good luck with them, but I wanted to "Buy American" so I purchased a Delta tablesaw. That was a big disapointment as it turned out to be junk and I will never buy another Delta. Then I started buying Powermatic tablesaws and joiners and was very happy with the quality and made in USA until a few years later they got bought out by Jet tools. Now I see Powermatic and Jet labeled tools that are exactly the same thing. Some of the stuff looks really good and some does not but overall I think the quality is right up there with other big names.
dr.sportster
02-11-2005 06:49:30
Jet is one of those companies that imports the stuff but checks accuracy somewhat before selling it.For imported[I cant believe Im say ing this] it is of decent quality.
dr.sportster
02-11-2005 07:18:00
 Re: Jet Tools in reply to dr.sportster, 02-11-2005 06:49:30
Disregard that last statement.I was on drugs[Dunkin donuts coffee].It is Imported semi-junk.Same advice as the band saw look for a used Made in USA.
BFO
02-11-2005 06:29:58
If you are a hobbyist or occasional user, they are fine. If you run a business then don't waste your money. You get what you pay for. I have the 22' drill press and had to throw away the chuck and replace it with a ball bearing type in the first two weeks, the output shaft on the motor snapped completely off one day, replaced it with a Dayton motor. Couple of other things that escape me right now..sorry I bought it.
My friend who does carpentry and millwork had to scrap his tablesaw after about a year, he bought a General, they're a heavy saw. HTH
DaveCA
02-11-2005 19:57:18
 Re: Jet Tools in reply to BFO, 02-11-2005 06:29:58
Right on BFO.
Not built very strong according to my experience. Don"t take much hard use and you"ll be hating it.
Better overall than some other Tawan/Chinese stuff though, atleast it will work marginally at the start.
Charles Park
02-11-2005 06:06:42
Jet is as close to the top of the line as you can get. In table saws, Delta is probably the No. 1 choice followed by Jet. Also, they carry a good price tag.
Pete in Cal
02-11-2005 08:38:33
 Re: Jet Tools in reply to Charles Park, 02-11-2005 06:06:42
I recently purchased a 12" Jet bandsaw and Jet floor mount drill press. The bandsaw is made in Taiwan, the drill press in China. Both appear to be of good quality. Had I known in advance the drill press was made in China probably would not have bought it just because of where it was made. I looked at Craftsman and Delta before making the purchase. Craftsman floor model had bent parts held together with plastic ties. Neither machine was worth taking home. Mentioned the obvious defects to the salesman who shrugged it off. Jet stuff is well made and appeared to be sturdy. Pete
