Tool Talk Discussion Forum
my new tool{hip replacement}
pperry
02-10-2005 05:42:13
since this is tool talk i figured i could ask you fellas about my new {steel on plastic cup}hip that will be install on feb 14,2005. i am 33yrs old and was born with a bad hip. this is my first surgery of any kind. any of you hip replacement guys have any pros and cons about before, during ,and after surgery. for example, how long untill i can be seated back up on my tractors?? im having withdralls just thinking about it...haha.. thanks ...
pperry
02-17-2005 17:16:22
 Re: my new tool{hip replacement} in reply to pperry, 02-10-2005 05:42:13
vicadin,vicadin,and more vicadin. i hate taking pills butt, there sure is alot of leg pain involed wiyh this surgery...oh ya , they lenghthened my leg 2 inches also
pperry
02-17-2005 14:45:03
thanks everybody for the info. i had my surgery monday morning. its now thursday and i made it home. surgery went well, i am walking using a walker. the car ride home was painfull. i start my therapy friday. thanks again for all the support.
Bud in NC
02-12-2005 05:04:31
Working on my second set now. Had the first installed when I was 39. Avascular necosis - I used to do some salvage diving and while I never got the bends I musta come close. My first set lasted 13 years - climbing ladders, walking concrete turbine decks, climbing on equipment to see why was wrong with it - about everything they said not to do. The first time I woke up in recovery with a 14" incission in my butt I felt better than I had in months! Do what the therapist says, do you exercises and other than that, don"t do anything that feels uncomfortable. It doesn"t really hurt when one of them pops outta socket - no nerves in the new stuff, but it"ll get you attention!!! Feels some kinda wierd and NOT plesent! Good luck shoot me an email if you have any specific questions and I"ll try to answer them.
JMS/MN
02-11-2005 12:00:28
Obey your rehab therapist! A neighbor had his hip done in his early sixties and always complained about the problems and pain. Of course, about as soon as he got home he was climbing the silo every day to feed steers. Didn't need the steers for the money, just wouldn't give it up. Everyone else I know with replacements have had great results- they followed the rules. Best of luck with yours!
Vern-MI
02-11-2005 10:42:47
Dad is ninety years old and had his hip replaced last June (2004). He twisted just right while out in the yard watering the grass and it snapped off. The neighbors hauled him inside and set him on the sofa while he was screaming in pain as his leg flopped about. Tried to get up to go to the bathroom in the middle of the night and finally they called the meatwagon to take him to the horsepital.
They selected the approximate joint size size which is the same as the one they removed and then cut off and drilled out the femur and then pounded in the new tapered shank with adhesive applied to the joint. Adhesive is used on older patients only. The femur grows around and attaches to the taper of the new appliance on a younger person. The whole leg is then rotated up and into a position where the new ball can be slipped into the socket and the leg is rotated back down into the normal position and the incision is sewn back together.
He was pretty much out of it for three days and then they started him on physical therapy. Two weeks later he was back home in a wheelchair. About six weeks after the break he was walking with a cane. He has no pain in that leg and is now complaining about his other leg.
Pretty slick what doctors and modern medicine can do. He said there was now way that he was going to let this get him down. He is back driving again and happy as a ninety year old can be.
dr.sportster
02-11-2005 07:31:03
Years back I was at an abrasives distributor that also contracted to do tumbling.We were in the back and the owner stopped a tumbler and pulled out a piece of metal and said Guess what this is.Thinkin I was smart I said titanium.He says yes but what is it.loked it over.It was odd shaped.I have no idea I said. He says its a replacement hip.We tumble them to smooth out the surface.Very interesting.I hope yours works good for you.
Bob - MI
02-11-2005 06:58:49
 Re: my new tool{hip replacement} long technical po in reply to pperry, 02-10-2005 05:42:13
I used to sell these devices back about 15 years ago but I was focused in the production of titanium products. I did however compete against "stainless steel" and learned a bit about it and the devices as a whole. If you ask your doctor he can tell you what name brand device you will be getting and you can then do research on that manufacturer"s website.
What most people refer to as "stainless steel" is actually an alloy with an ASTM designation of F-75. This is a metal that has cobalt and chromium as it"s primary alloy elements. The properties of this material are focused in the direction or corrosion resistance due to the body"s warm temperature and high salinity, similar to sea water. This alloy was sometimes used in high temperature turbine engine applications.
The hip replacement (if it"s what they refer to as a "total hip") consists of a stem, a ball, and a cup. The stem is inserted into the femur after it is hollowed out to accept it, the ball is attached on the top of the stem (taper lock fitting) and the cup is installed in the pelvic area. The cup has a high grade polyethelyne insert in it to act as a bearing surface when you walk. Newer systems incorporate high-density ceramics to enhance wear and longevity.
There are numerous designs out there and they all have distinct advantages. Most of the implants made in the US come out of Warsaw, Indiana. Major players in the market located there are : Zimmer, Biomet, and Depuy - a division of Johnson and Johnson. They all have informative websites.
The stem may be made by the investment casting process (most are) the ball and the cup shell will likely be machined from solid stock. Lots the major players in implants have their own investment casting facility in-house.
You are pretty young for one of these and I suspect that you are in quite a bit of pain and have lost range of motion. The pain will be greatly reduced after the operation. The range of motion regained depends on the individual but in the end, there"s generally nothing as good as the original equipment.
Very best of luck
Scott Green
02-11-2005 04:51:26
No personal experience. Have talked to many people that have had hip replacements. Nothing but positive comments.
upred
02-10-2005 19:23:35
my neighbor was about your age when he had his replaced (his was bad from a car accident) he could barly walk before now he feels great, Doc thinks he should get around 30yrs use, then it might need replacement, but he has an older model not the new high tech one like your talkin about. I think you will be surprised how fast your up and movin around better than new -- Good luck with the overhaul and let us know how your doing-- Rick
kidbob
02-10-2005 19:18:50
Hi there, I�m glad to here you are going to get a hip replacement. I had a hip replacement done June 2003. I was on crutches 6-7 weeks, then using a cane for 3 weeks I think it was. I limped quite a bit for about a year. But I am walking so much better now. I was in quite a bit of pain from a worn out hip. I�m really happy with my new hip. If I hadn�t gotten it done, I wouldn�t be able to do the things I like to do. I raise goats and other animals. I work in the kitchen in a hospital and am on my feet 7-8 hours a day. I think you will be very happy with a new hip. Not sure when they will let you back on a tractor, but when you do it will be so much better. I was not born with a bad hip so don�t know exactly how yours feels or anything, but I do hope yours will do as good as mine did. I�m not a guy, but my husband is a former farmer and he thought I should write to you about my hip, so I hope this helps you to feel good about getting one. I was pretty nervous about getting it done also, because I�m very active and I was to the point I was working on crutches. I was afraid I wouldn�t be able to do my work anymore. But I�m back to work with my animals and at the hospital, so I�m very happy. Also I guess I should tell you I�m 54 and I bounced back so a young one like you should really bounce back. Good luck. Sincerely Cathy
Dave in GA
02-14-2005 04:39:52
 Re: my new tool{hip replacement} in reply to kidbob, 02-10-2005 19:18:50
Cathy, you work in a hospital kitchen? So do I (Emory-Atlanta). I'd rather be tinkering with old tractors, but income has to come from somewhere. The word around here is that hip replacements have become routinely successful but the recovery is slow and sometimes painful. I've had employees with hips and knees replaced, and these are people who are on their feet all day. The knee people return sooner than the hip people, but the hip people complain less than the knee people a few years down the road. I've had more staff with rotator cuff problems (shoulder) and they never are the same after surgery.
Gene Davis (GA)
02-10-2005 19:09:28
Don't know about the hip joint, but wouldn't take the proverbial gold geuinea for my knee replacement joint! Workd great. Gene Davis
02-21-2005 16:34:27
 Re: my new tool{hip replacement} in reply to Gene Davis (GA), 02-10-2005 19:09:28
Hey, Gene: a lady friend had several hip replacements done over the past 10 years or so. But they never seemed to last! So, when she went in last December for another one, i told her to ask them to install a Snap-on Universal (For mechanical work)! I thought it would last lots longer than the other ones! Well, the Dr. installed a new type, and he thinks it will last longer. She's walking around on it, says it feels good, a little pain yet. I told her to drink a beer a day and it would get better quicker than being a tee-totaler! It has worked for me, keeping me in good health! Rustyj
