Tool Talk Discussion Forum
oil check valve that needs 10 psi to open???
Georg
02-08-2005 23:28:26
Is there a check valve for a 1/8 to 1/2 inch oil line that only allows hot oil to go one direction and then only after pressure excedes 5 psi? Where can I get one?
kidbob
02-09-2005 21:01:19
 Re: oil check valve that needs 10 psi to open??? in reply to Georg, 02-08-2005 23:28:26
These are available from many hydraulic component distributors. If you can not find one I can get it for you.
