Tool Talk Discussion Forum
Lincoln SA-200 weak spark.
Mike from cny
02-07-2005 21:31:24
Had the welder going tonight. Tried welding with it and had a weak yellow/orange spark. I have good power to the 110v outlet. Not really sure where to go from here, Any suggestions? Thanks a million guys.
B. Davis
02-12-2006 17:34:12
 Re: Lincoln SA-200 weak spark. in reply to Mike from cny, 02-07-2005 21:31:24
just like the other guys said try cleaning the exciter with a copper (soap stone) and then check your main armature under the cover and clean it as well, and then if that does not fix the problem you might then have shunt field coil problems.
Richard Fazio
02-11-2005 11:20:14
Mike, I asked you this before but I don't think you saw the post. When you try stricking an arc does you engine rev up?
Jerry L /AZ
02-08-2005 04:09:08
might start buy cleaning the armature and brushes on the generator hopethat helps...Jer
cannonball
02-08-2005 15:11:46
 Re: Lincoln SA-200 weak spark. in reply to Jerry L /AZ, 02-08-2005 04:09:08
check what jerry says and while you are at it make sure brush is touching ...my brush holder would rust up and not alow the brush to touch..have nice day may god bless
