Tool Talk Discussion Forum
Webster hone adapter
Davis In SC
02-04-2005 19:25:24
I promised to look in Sunnen catalog for adapter to use Sunnen Mandrels on a Webster Machine.. Sorry, But I did not see an adapter listed. Might be worth calling Sunnen, They might could help you.
dr.sportster
02-04-2005 19:45:23
 Re: Webster hone adapter in reply to Davis In SC, 02-04-2005 19:25:24
Thank you.Im going to keep checking ebay.
george md
02-04-2005 20:03:43
 Re: Webster hone adapter in reply to dr.sportster, 02-04-2005 19:45:23
dr, I found the catalog from superior hone.
phone # 1-800-237-2328
part # W-2000
Superior stones last at least 10 times as long as sunnen , it is a 2 stone machine , so the work never touches the mandrels .
george
Davis In SC
02-04-2005 20:41:21
 Re: Webster hone adapter in reply to george md, 02-04-2005 20:03:43
Hi , George... Interesting about Superior hone, I have never had any experience with one. I think you will agree with me on one thing... tooling up a honing machine gets expensive!!! I bought a new Sunnen about 6 years ago, with the standard fractionals up to 3/4 inch. Now , I buy odd sizes only as I need them. Most expensive ones to run are the small ones in the 1/16 range, it is easy to use up a hundred dollars worth of stones in an hour....
george md
02-04-2005 22:03:09
 Re: Webster hone adapter in reply to Davis In SC, 02-04-2005 20:41:21
Davis,
I bought a sunnen machine about 25 years ago at an auction for 100.00 with mandrels 5/8 to 1 in
typical garage set. I did truck and ind engines so I needed larger ones, bought enough to make a
set to 2 inch and sizes above as I needed them.
One of the first mandrels I got was 2 inch in fits
cummins, mack , and cat piston pin bushings.Takes
about 2 hr to do a set for cummins or mack and most of 6 hours to do a 3406 cat , the first set
of stones on that mandrel lasted 10 years and I
think they cost 14.00, I have no idea how many sets
of those bushings I did.
The smallest that I have is just under 1/2 ,and
the biggest is 3 inch.
Below 3/16 superior uses single stone mandrels. You are right , hone tooling is expensive.
george
dr.sportster
02-04-2005 20:36:02
Oh, w-2000 is the adapter number.Thanks George and Davis.It will be nice if I can get it to work.Ill call Superior.
