I'd like to jump in here from a cold start, missed the prior discussion. First, your demand is not that high but high enough to warrant doing it right rather than doing it multiple times. I strongly suggest you seriously engineer your system around both your current requirements as well as FUTURE NEEDS (these are what 99.9% of forget about and wind up paying for many times over). You say your current needs are 30 cfm normal with 60 cfm spikes, if I recall from your post. 30 cfm can be handled quite easily with a recip compressor however when you get over about 45 cfm, you begin loose efficiency in several ways. First, the machine will be running at capasity as in wide open throttle which means it'll be running hotter and promoting advanced wear on the internals. This can be countered somewhat by adding an oil cooler, air cooler, ect but you're also adding considerable hardware cost and operational maintenance costs as service intervals will need to be much shorter. Without knowing your exact requirements, there is no way I can make any judgement on what machine(s) you need. Engineering a compressed air system is far more than just picking a compressor with the capasity to handle the load. Distribution piping must be properly sized & designed which may include additional storage units at key points, positive looping and so on. You may be better off in the long run having higher start-up costs by investing in two compressors, one a recip, the other a screw both working in tandem on the single system. On the other hand you may be best suited with two completely separate systems or a combined dual system. Then again, your application may be handled by a dual unit recip or may be even more efficient and cost effective operated on a single screw. You obviously have a requirement that definitely warrants further consideration by a qualified application designer. DO NOT rely on sales idiots to design your system because if they were designers, they would not be working as a salesman. Now, there are compressor companies that have a design engineer on staff who is qualified to design the system and size the unit(s) properly in exchange for buying their product. Other companies will direct you to the third party engineering who you will have to pay for their services. In either case, you must CYA by getting in writing a guarantee that will protect you if the system does not perform as designed. You also need to provide in writing your current as well as your future needs BEFORE any design work is done otherwise your engineering guarantee is useless if you try to collect. Side note: I have first hand experience with an IR T-30 25 Hp recip compressor and without writing a novel on what was wrong with it out of the box, I will simply say that I have no interest in purchasing anything with "I-R" on it anymore. I really don't know what happened to this company but they definitely are not what they used to be.
